PCV Valve rattle?
Old Nov 1, 2002 | 06:10 PM
SpecR_EK's Avatar
New User
Default PCV Valve rattle?
I just bought a new PCV valve and I was wondering should it rattle , like it's got beads inside, when you shake it?
Old Nov 1, 2002 | 06:37 PM
Chiovnidca's Avatar
Default Re: PCV Valve rattle? (SpecR_EK)
Some of them do. It's ok.
Old Nov 1, 2002 | 10:03 PM
jayro's Avatar
I bought a new PCV from Discount Auto...one of those Fram $2.49 deals. Stuck it in there, and man was that thing LOUD. So loud, that with the hood closed and windows up, I could still hear it. I didn't like that too much so I went to the honda dealer and bought a OEM PCV for $22.00 No rattle at all, so I was happy.
You get what you pay for
Old Nov 1, 2002 | 10:26 PM
SpecR_EK's Avatar
New User
Default Re: PCV Valve rattle? (jayro)
Dayum, your PCV actually made that much noise? I bought one of the cheap ones from Autozone and can't hear it when the engine is in operation.
Old Nov 2, 2002 | 12:04 AM
b19coupe's Avatar
Many aftermarket PCV valves flow too much air and cause the vehicle to run lean. Stick with OEM PCV valves, worth the extra change.
Old Nov 3, 2002 | 09:15 PM
SpecR_EK's Avatar
New User
Default Re: PCV Valve rattle? (b19coupe)
Doesn't make sense since the ECU since compensate for any extra air.
Old Nov 4, 2002 | 12:06 PM
b19coupe's Avatar
Let me clarify-a PCV valve that flows too much air at idle is like a vacuum leak. Very little effect above idle. At idle, the EACV (IACV) can usually compensate for the extra air.
pityocamptes
26
Mar 25, 2016 10:23 AM
eHMxhACk
Mar 23, 2014 10:41 PM
Ryan111987
Honda S2000
33
Apr 13, 2009 11:51 AM
Dav94Lx
Oct 9, 2007 07:53 PM
mickey513
Jul 17, 2002 12:21 PM
