speedo not working
Old Oct 29, 2014 | 10:33 AM
OJdm's Avatar
Default speedo not working
So as I start driving this car more and more, more stuff just seems to start breaking or I catch problems before they happen. (car has been sitting for 6yrs)
Driving one day and the MPH needle starts to bounce all over the place, then it just quit and I got a CEL for a VSS. So replaced it, and problem not solved. Sensor came out of a working transmission. Checked voltage at plug and for good ground. so my question is if the harness is good and sensor is good, maybe the cluster?
I was searching on the forum thats the only other solution i seem to find. unless I'm missing something else. any insight would be great.
1993 civic dx 3dr w/ b18b stock.
Old Oct 29, 2014 | 10:35 AM
Former User's Avatar
Default Re: speedo not working
Check for a corroded VSS connector (wire harness side). Replace if necessary.
Old Oct 29, 2014 | 10:36 AM
09chaplak's Avatar
Loves Tossing Salad
If all that stuff checks out, I've seen a cluster replacement work for the most part. Same thing happened with my tach, swapped it for a working cluster and it worked just fine. Got another one handy somewhere?
Old Oct 29, 2014 | 02:32 PM
OJdm's Avatar
the connector was a little corroded so i de-pinned it and cleaned it as best as i can.
so as I was driving on the highway today the speedo needle started to just bounce around a bit, then just started working. so I shut off my car, yes on the highway. Coasted for a while then turned her back on, and the speedo started to work and the CEL went away. Thought that was pretty weird. But I think the MPH is off a bit.
But now at least I have an idea of how fast I'm going, instead of just sticking my arm window and guessing.
thanks for the help!
Old Oct 29, 2014 | 02:44 PM
Fraser1989's Avatar
http://www.tegger.com/hondafaq/tsb/civic/x99-029e.pdf
That was the solution for me
Old Oct 30, 2014 | 09:14 AM
OJdm's Avatar
checked the fuse, and this TSB above^. still no permanent solution. gonna shop around for a gently used cluster and try that.
Old Oct 30, 2014 | 09:19 AM
You may want to try resoldering the pins to the wires
Old Oct 30, 2014 | 10:19 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
It could also be bad solder joints on the cluster circuit board as seen in this thread:
https://honda-tech.com/honda-civic-d...r-fix-2792878/
Old Oct 30, 2014 | 10:41 AM
...or sometimes people overtighten the screws at the rear of the speedometer. Sometimes this issue is reparable, sometimes not.
bboyjimpy
16
Mar 16, 2008 06:28 PM
civicEXtreme
Dec 15, 2007 03:10 PM
burgandybeast
Nov 2, 2007 02:30 PM
confusion
May 13, 2007 02:22 AM
JiVe
19
Jul 22, 2003 01:12 PM
