FULL SWAP VX TO EK 2000 HATCH
Old Oct 22, 2014 | 05:56 AM
james518's Avatar
Default FULL SWAP VX TO EK 2000 HATCH
I would like to know if this swap can be done motor and all, what is needed and if theres anything special that has to be done,wiring cluster any help will be appeciated.
Old Oct 22, 2014 | 06:11 AM
Norlael's Avatar
Default Re: FULL SWAP VX TO EK 2000 HATCH
Old Oct 22, 2014 | 12:17 PM
HondaPartsHero's Avatar
Technical Hero
First off do emissions in your area require the plug in or require that the engine be the same year or newer in your car?
Old Oct 22, 2014 | 04:27 PM
james518's Avatar
i live in california , i am looking to get best mpg and economic tranny swap
Old Oct 22, 2014 | 05:36 PM
speedjunkie_g35's Avatar
From: Pensacola, FL and every Court House in Louisiana
Federal law requires any replacement motor to be same year or newer for emission reasons. So good luck passing that in Cali! Get a cx/vx transmission to improve mpg.
Old Oct 22, 2014 | 07:24 PM
tony_2018's Avatar
Fish Twig
Its pretty straight forward what you need already, engine, engine harness, ecu and the oem wideband o2 sensor.
Old Oct 25, 2014 | 02:14 AM
Technical Hero
California?
Encino Man wave gif - PandaWhale
Old Oct 31, 2014 | 05:42 AM
construct1's Avatar
Instead of the vx motor use an hx very similar motor and for Cali you can put it in your car legally.
In Cali the vx ECU does not use leanburn anyway it uses a reg 4 wire o2 because emissions... but still gets good mpg
The hx does not have leanburn for Cali emissions again but you will still get excellent mpg. And can get one for your car they made hx's till 05
Everywhere else vx's and hx's have leanburn its just a difference in ecus and 5 wire o2
sensor
Put in a hx get a 48 state ECU run a 5 wire o2 and when it comes time for emissions get a Cali ECU and 4 wire o2 you'll be legal and pass emissions
Old Nov 5, 2014 | 04:36 PM
james518's Avatar
Thanks i will get it done and post result ,thanks for your help if theres anything that you missed let me know, Im going with the HX 96 manual swap into my eK, i already have the Hx rims with LRR tires so thats a start ,again thanks
civic92vx
10
Feb 5, 2011 06:46 PM
Enginear
May 20, 2008 01:25 PM
fogged306
Jan 31, 2008 04:26 AM
CHK4TIX
Dec 4, 2006 06:20 AM
SilverGT
16
Nov 25, 2006 02:48 PM
