93 del sol b20b engine swap kinks
Old Oct 12, 2014 | 11:14 AM
93Del_soul's Avatar
Icon2 93 del sol b20b engine swap kinks
Just swapped my b20z2 for a b20b, it idles fine but in the low rpm range it surges, it almost sounds like its hitting a rev limiter, but in the higher rpms its fine. i changed out the distributor, spark plugs, intake manifold, throttle body, fuel rail and alternator. everything else that is on the new engine came with it.
a friend of mine called his friends grandfather who is/was a mechanic and he says that the computer system is searching for the timing, he recommended that i take it somewhere and have it reprogrammed. is this right? or is it another issue?
Old Oct 12, 2014 | 11:20 AM
joey1320's Avatar
Default Re: 93 del sol b20b engine swap kinks
You friends' grandpa is incorrect.
But before we dig into it, please read the sticky/rules and provide us with all the necessary info in order to help you diagnose this issue.
Old Oct 15, 2014 | 02:01 AM
HondaPartsHero's Avatar
Technical Hero
How did you wire up the distributor? Injectors? Check engine light on? Check for vacuum leaks as well since you changed out the intake components.
Old Oct 21, 2014 | 03:09 PM
93Del_soul's Avatar
sorry for the super late reply, i have been real busy.
the check engine light is on,
the distributor and injectors are off the old engine. i used the old distributor because the plugs on the new distributor didn't plug up to the wiring harness.
i hooked up the intake mani the same way it was on the old engine with the assumption that it would work. but i did look around and found that there is some vacuum related parts disconnected, but they were disconnected on the old engine i'm assuming i should re-do the vacuum lines the proper way and not plug them with screws like they have been.
Old Oct 21, 2014 | 03:37 PM
Technical Hero
Pull the Codes and post them
Old Oct 22, 2014 | 02:57 AM
93Del_soul's Avatar
How can i read the codes on obd1?
Old Oct 22, 2014 | 12:15 PM
Technical Hero
https://honda-tech.com/honda-civic-d...lists-1901557/
Old Oct 27, 2014 | 08:28 AM
93Del_soul's Avatar
One Short flash two long flashes then four short flashes.
Old Oct 27, 2014 | 08:32 AM
93Del_soul's Avatar
Then the code repeats
Old Oct 28, 2014 | 04:18 PM
Technical Hero
Can you post a vid?
Old Oct 30, 2014 | 02:54 AM
93Del_soul's Avatar
Can you post a vid?
Sadly i can't post a vid
But i can email it.
I'll keep trying
Old Oct 30, 2014 | 07:11 AM
93Del_soul's Avatar
Can you post a vid?
Unfortunately i can't post a video:/ but i can email it.
I will try to post the video again after work.
Old Oct 30, 2014 | 06:25 PM
93Del_soul's Avatar
cant seem to post a video
Old Oct 31, 2014 | 06:41 AM
Technical Hero
You have to sign up for youtube or a photo site that allows you upload video. Then post the link.
Old Nov 1, 2014 | 07:32 PM
hybridmiklo's Avatar
if its one large flash and two short flashes you are using an auto ecu. Wrong ecu. code 12 is for egr issue. EGR only came with autos
Old Nov 3, 2014 | 07:28 PM
HiProfile's Avatar
Maybe 3 codes: 1, 10, 14. O2 sensor, IAT, and IACV - oddly enough all 3 could be working improperly to result in your surging. Either the IAT is missing or you pluged the connector onto the wrong item (different spot between engines). Code 1 could be from it running way too lean or rich, or just being bad and causing it to run rich or lean. If the IACV is plugged or bad, that could definitely cause surging.
86aw11
Dec 28, 2015 05:35 PM
da_ford_man
Oct 23, 2013 03:53 PM
TunerFreak24
19
Nov 17, 2010 09:06 PM
TampaBoy
Dec 11, 2008 04:05 PM
SmokeU
Nov 5, 2003 11:35 AM
