Timing Belt Help..
Old Oct 10, 2014 | 10:28 PM
duh702dc2's Avatar
Default Timing Belt Help..
Hi everyone I have a 97 b18c JDM type r swap in my teggy an I changed the timing belt and water pump all OEM. I didn't change the tensioner cuz it looked brand new. I bought this motor few months back. Anyways I got the timing all right but the belt is riding on the side of the cams. I have posted a video below to show what I mean.
Basically I'm wondering if its normal or a problem. I've ran the car for about 10 min to see what happens an it stays exactly where it is.
Any help would be appreciated very much.
Old Oct 10, 2014 | 10:29 PM
duh702dc2's Avatar
Default Re: Timing Belt Help..
Old Oct 11, 2014 | 06:08 AM
Runnerdown's Avatar
Doesn't look too bad..
Do you have the belt guide washer on the crank?
Old Oct 11, 2014 | 08:54 AM
duh702dc2's Avatar
Yes sir I do.
Old Oct 11, 2014 | 01:26 PM
cumminR's Avatar
Is the belt walking? As in does does it move towards the end of the cam gear while running? could always line it back up loosen the tensioner and move it in a smidge
Old Oct 11, 2014 | 02:01 PM
duh702dc2's Avatar
I've tried loosing it an moving it over but it goes right back to that spot.
It isn't riding off or anything. Its just close to the edge. Makes me nervous lol
Old Oct 11, 2014 | 03:50 PM
4dooritr's Avatar
Pull all the pulleys off and check for anything in the way, make sure the guide washer is in the correct position.
At this point you may want to replace the tensioner and spring, its not that expensive and check the tensioner bolt for straightness.
It doesn't look bad but its better to make sure.
Old Oct 16, 2014 | 03:47 PM
wunfstgsr's Avatar
Loved
Community Favorite
Its the guide washer behind the crank pulley, i did this once and the belt walked and started to burn through the valve cover! You need to flip the washer around.
Old Oct 17, 2014 | 01:24 AM
duh702dc2's Avatar
I have the washers on like this. Let me try an use symbols on here lol.
]belt[
Old Oct 17, 2014 | 12:37 PM
wunfstgsr's Avatar
Loved
Community Favorite
VegaS10
May 20, 2013 12:05 PM
zmods
Mar 20, 2011 03:06 PM
---NON-VTEC---
Mar 30, 2008 11:54 PM
aaaabbbb
Oct 5, 2004 03:02 PM
YellowCivicE
Jul 12, 2004 06:57 AM
