Tint adhesive off the back window....
Old Oct 4, 2014 | 02:28 PM
Kyle700's Avatar
Default Tint adhesive off the back window....
Off the rear window with defroster, all that is left is the glue. So far I have tried EZ-Off oven cleaner, dishwash soap/water, ammonia and steam. The ammonia worked the best for taking off the second (clear) layer of tint but it wont do anything to the glue. I have also tried #0000 steel wool with all chemicals...anything else to try?
Old Oct 4, 2014 | 02:46 PM
CD8's Avatar
CD8
Default Re: Tint adhesive off the back window....
I used a razor blade, but then the rear defroster didn't work well
Old Oct 4, 2014 | 04:15 PM
NotARaCist's Avatar
I never narc'd on nobody!
Goo Gone. Let it soak in before trying to wipe it off. Put some elbow grease into it.
Any kind of damage to the rear defroster wires will kill it.
Old Oct 4, 2014 | 06:21 PM
tony_2018's Avatar
Fish Twig
I have the same issue. The old tint wouldn't come off completely, I'm now looking into a portable pressure steamer to really loosen up the rest of the glue.
Old Oct 4, 2014 | 06:50 PM
EsotericImage's Avatar
Retired Moderator
The old tried and true method was to use a trash bag and ammonia..
Spray alot of ammonia on the glass, then lay the plastic bag over the ammonia.. let sit in sun for a few hours and everything should come off pretty easy.
leftover glue can be wiped off with steel wool but make sure to go with defroster lines and not across them.
Old Oct 4, 2014 | 09:24 PM
tony_2018's Avatar
Fish Twig
Its hard to lay the trash bag on. It always fall
Old Oct 4, 2014 | 09:36 PM
DOHCtR-V's Avatar
crl quick release agent for stubborn glue, & glass cleaner to clean up afterwards.
CRL takes off almost anything, careful with rubber,it tends to dry rubber a bit.
You'll need rubber Wurth care treatment if you get CRL on it.
(Not "instadry", long term use).
Wear gloves, eye protection(since its a rear window) for back spray.
Old Oct 5, 2014 | 10:59 AM
spAdam's Avatar
Loved
Community Favorite
Best thing I ever did was steal my lady's clothes steamer to strip tint. If you're slow and patient it all comes off in one piece, a wipe with 75% Windex/25% ammonia will take the remaining residue off, and your fingers only get slightly burned. Didn't use a single razor blade or anything abrasive.
If it came off in two layers as you described, you're already kinda F'd on that method though. Keep working with ammonia based solvent and avoid abrasive anything.
Old Oct 5, 2014 | 12:37 PM
eHMxhACk's Avatar
yippee-ki-yay
10 Year Member
Or Goof-Off. Both are adhesive removers and work very well.
eH.
Old Oct 5, 2014 | 03:18 PM
90si-rex's Avatar
What he said. I used a steam cleaner to remove my tint and it came off so easy. All of the other methods seem to leave a fair amount of adhesive behind but a steamer seems to get pretty much all of it in one go.
Old Oct 6, 2014 | 04:47 PM
yhammer's Avatar
I'm a auto trimmer. the steamers we use for work, would be ideal for removing tint. we use a steamer wand that pin points steam. so asking a trimmer might be a option.
Old Oct 6, 2014 | 05:44 PM
spAdam's Avatar
Loved
Community Favorite
I've seen those, that's where I got the idea for the clothes steamer (I bought it for her anyway, lol).
Old Oct 6, 2014 | 06:29 PM
crazyhouse2011's Avatar
decal remover
Old Oct 6, 2014 | 10:02 PM
Retired Moderator
Ive never had any problems using the trash bag method. Went up and stuck just fine.
But whatever.
Old Oct 9, 2014 | 10:22 PM
JDM CTR '00's Avatar
Works great
Old Oct 10, 2014 | 07:02 PM
Former User's Avatar
An inexpensive Conair compact fabric steamer from Target worked great for me. Only minor glue residue remained and cleaned up pretty easily.
vtec_head
Jul 21, 2008 08:15 PM
ramos2589
Paint and Body
Jun 23, 2008 04:12 PM
9hatch6
May 20, 2006 01:20 PM
shivern
14
Oct 20, 2004 04:58 PM
Kimbo
11
Mar 31, 2004 12:01 PM
