Civic d16 clear timing cover installed
Old Oct 1, 2014 | 08:53 PM
chrysler kid's Avatar
Default Civic d16 clear timing cover installed
Since I only found two threads on google with only two pictures of the product installed I thought I would post pictures of mine. With my Hx having 300k miles I needed to check the belt anyways so for $20 shipped I wanted this extra piece of mind
I stopped at autozone and picked up a fresh valve cover gasket, I should also suggest that if your car has over 200k I highly suggest getting new valve cover bolts. Mine were extremely weak and one broke at not even hand tight
[/QUOTE]
so as i alluded everything wasn't as easy as planned. The cover fitment was decent but it was much tighter than my factory 300k miles cover. My factory cover had the tab broken off on the back side of the timing cover and appeared to have forced the guides on the rear cover assembly. I needed to make the grooves a little wider on the clear cover to fit it back onto the rest of the rear cover
I also broke a valve cover bolt off in the head however it came out extremely easily thank god
Pretty clean for 300k miles
Only a little bit of build up.
Timing belt is a fresh Kevlar. Good to see the previous owner was honest about maintenance
Grrrrrr
All wrapped up. Pleased with the results, only $20 shipped for the clear timing cover
Overall I do highly recommend the cover for the extra piece of mind and I also think it will add value when it comes time to sell so the next owner can inspect the belt immediately. It has been a week and the cover has remained clean and clear
Old Oct 2, 2014 | 05:37 AM
Default Re: Civic d16 clear timing cover installed
Originally Posted by TomCat39
One word of caution. I believe the clear plastic has different characteristics over the standard belt cover plastic.
I noticed with my clear distributor cap, the plastic hardened much faster than the regular black plastic of an OEM cap.
The same might be true with your belt cover. Check it in 6 months and inspect it for cracks, yellowing etc. The heat in the engine compartment takes a slow toll on plastics. I believe the plastics Honda chose were for longevity over visibility or vanity.
Thanks for the tip sir. The clear unit was of the same thickness but I believe you are correct about the polymers used in the factory piece.
I am hoping since everything connected to the cover is already plastic (with the exception of the rear mounting bolt and tab) that it should last a good while.
I have a friend who has a real aem? I think, clear timing cover on his twin turbo 300zx and it has held up fine for over 5 years now and still looks new
Old Oct 2, 2014 | 06:36 AM
taco_hut's Avatar
Where'd you get it? I sorta want one
pityocamptes
19
Jul 24, 2013 08:35 AM
rice h8r
Jul 15, 2011 09:32 PM
GrnZ
Mar 25, 2008 06:49 AM
Seatown
Nov 9, 2006 02:14 PM
alotawatts
10
Dec 20, 2004 09:51 AM
