Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
lots of white smokes comes out of my civic.
Old Sep 28, 2014 | 07:33 PM
Mosal's Avatar
Default lots of white smokes comes out of my civic.
Hi,I have a 2006 honda civic,and I am new in here and facing a big major problem. And need for some help. So we just put in a used engine in my honda civic. Me and my friend did everything in the right way and now when we turn on the car, the engine turns on for like 3 minutes and after that it shakes and turn off itself. and lots lots of white smoke coming out of tail exist pipe. when I push it makes more white smoke. Any help would be appreciated. Thanks
Old Sep 29, 2014 | 11:57 AM
DaveSi677's Avatar
Default Re: lots of white smokes comes out of my civic.
What motor did you put it?
Also white smoke means you are burning coolant so you can be looking at either a blown head gasket, a damaged cylinder head or a cracked engine block!
Old Sep 30, 2014 | 05:53 PM
97emsedan's Avatar
Coolant leaking into cylinders. This is accumulating in the chambers and choking out the plugs.
Check your intake gasket.
Old Oct 6, 2014 | 06:14 AM
Mosal's Avatar
i just put a new 1.8l engine with 55k and its came out of 2009 aromatic engine, and mine is manual.
Old Oct 6, 2014 | 06:22 AM
Mosal's Avatar
i changed the engine because the old one was over heated and I think it had blowen headgasket and were doing the same thing, but with this one it's doing the samething and the engine shakes and turn off itself. When I checked the codes yesterday. It was saying random multiple misfire detected, and cylinder 3 and 4 misfire detected. So I changed the coil and spark plugs and now cylinder 2 and 3 misfire and engine shakes and turn off itself, engine light blanking and I really don't know what to do next. I really appreciate for all your helps. I am looking forward to fix this.
Old Oct 6, 2014 | 04:47 PM
97emsedan's Avatar
The older 1.8 blocks had a weak spot that cracked over time. This might be one. You should get it looked at soonest.
Old Oct 8, 2014 | 05:58 AM
DaveSi677's Avatar
Agreed with this... You should get it looked at asap.
Did you guys check the engine before buying it?
Old Oct 16, 2014 | 03:20 PM
Mosal's Avatar
So I replaced the spark plugs and coils from my old engine and even changed 02 sensor and the engine sign is gon now and runs. But the engine shakes a little and I have no idea why? And this is the third gallon of coolant that I am putting in. So anyone knows why the engine shakes and white smoke is coming from the tail????
Old Oct 16, 2014 | 03:46 PM
97emsedan's Avatar
I told you already, the intake gasket or the head gasket isblown, or the block is cracked. The coolant is getting into the cylinders ( if you replaced the plugs, which one was grey?) and the coolant is mixing with your intake charge. This is preventing the engine from burning the fuel and it gets rough.
Listen to the people who have posted answers to your question and follow up with some investigation if your own.
Otherwise, you will watch this engine detonate and you will be out the cash for another one.
Old Oct 16, 2014 | 04:12 PM
DaveSi677's Avatar
Apart from all this great advice I think you should do yourself the favor and stop playing mechanic!
Go get a professional to check it out!
Old Oct 25, 2014 | 12:02 PM
Mosal's Avatar
So finally I have found out that they gave me a blown headgasket engine and they take this one and give me another one. So when I checked the oil and oil dipstick, the oil looked like milkshake.so it was the headgasket. I wish I should have checked it before I put the engine. Thanks for all your help guys. I had to take this engine out and put the new one.
TheFamilySign
35
Mar 3, 2014 12:12 PM
J3ST3R562
Nov 18, 2013 01:01 PM
jaypapes12
Jun 13, 2013 02:22 PM
project ak
Jul 28, 2006 03:00 AM
turbolude99
Nov 5, 2004 01:02 PM
