having rev problems. Need help!!!!!
Old Sep 28, 2014 | 09:52 AM
Mr.Galloway's Avatar
Default having rev problems. Need help!!!!!
Start car and idle is fine. But push on the throttle peddle slowly and the rpm jumps up and down until about 3 grand then it becomes normal again. I need some help can't figure this out.
Old Sep 29, 2014 | 04:57 AM
ef-hatchcrap's Avatar
Default Re: having rev problems. Need help!!!!!
Is the engine running normal when this happens? there is a ground wire on the back of the cluster that can loosen up and cause the same issue.
Old Oct 2, 2014 | 02:14 PM
Turn the car on and its fine at regular idle. But if I hold the gas peddle down alittle bit it just revs up and down up and down. Until about 3000 rpm then the rpm just shoots up
Old Oct 3, 2014 | 06:46 AM
crazyhouse2011's Avatar
TPS
Old Oct 3, 2014 | 09:11 AM
Replaced TPS, IACV, MAP sensor, throttle body. Vacuum leak maybe?
EH3 JR
Nov 6, 2009 09:57 PM
94Integra_Ls
Feb 14, 2007 10:01 PM
Linh.
Jul 3, 2006 09:08 PM
rcjustin
26
Feb 3, 2006 10:37 AM
RineRacing
Sep 26, 2005 10:51 AM
