Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Ignition diagnostics help.
Old Sep 26, 2005 | 10:09 AM
RineRacing's Avatar
Default Ignition diagnostics help.
Like the fool I am I decided to convert my car to an electronic advance distributor only 2 weeks before my license test. I got all the parts and hooked everything up and the car isn’t running right. It car fires up just fine and I can get the car to idle two different ways, both of which are unacceptable.
1. The car fires up and idles around 1200 rpm then dies within 10-20 seconds. Sometimes it doesn’t idle but it I rev the engine it stalls when the revs drop back down.
2. I can set the throttle stop bolt to keep the throttle at 4% and the car idles at 2000 rpm, doesn’t stall and I can rev the car without it stalling. The problem here is that at part throttle the car really runs like crap.
I assume that most of the crap running is due to a poor a/f mix but it doesn’t explain the sudden stalling from idle or rev dropping. I tried adjusting the overall fuel map +/- 10% and neither direction seems to help the idle. The intake manifold gasket was leaking and replaced but the same problems exist. The ECU is giving no codes (ELD and ICV disabled).
Any suggestions on what could cause the engine to shut off like this?
I don't have a VSS wired to the ECU but I assume this wouldn't cause a problem.
Car: 87 CRX Si (stock motor)
Mods: OBD1 Distributor, OBD1 P28 w/ S300, 4 wire O2 sensor.
Old Sep 26, 2005 | 10:36 AM
nfn15037's Avatar
Default Re: Ignition diagnostics help. (RineRacing)
Do you have a wideband hooked up? That will speak volumes as to whether it is a fuel or spark problem.
Old Sep 26, 2005 | 10:51 AM
RineRacing's Avatar
Default Re: Ignition diagnostics help. (nfn15037)
I put it on the dyno w/ wideband using the second idle setup described above. For some reason I couldn't get a reading below 3k rpm but at WOT the car was a little lean from 3k to 5k then progressively more rich from 5k to 6.5k. This was with the leaking intake manifold gasket which I believe was causing the low RPM lean levels.
sushibug
Jan 13, 2025 05:07 AM
DuecedSol
Honda Civic (2006 - 2015)
10
Aug 8, 2014 07:26 PM
erichackett
10
Jul 27, 2010 06:43 PM
vtec94civic
Aug 9, 2005 03:35 PM
