1999 Accord 2.3L
Old Sep 26, 2014 | 06:56 PM
Ryan Hammond's Avatar
Default 1999 Accord 2.3L
Need help my car is surging while driving and the dash and headlights are flickering, already cleaned the EGR passage. Any ideas?
Old Sep 26, 2014 | 11:26 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: 1999 Accord 2.3L
Have you monitored voltage at the battery?
If the charging system is not maintaining a steady voltage it may cause the engine to run rough.
Old Sep 27, 2014 | 03:52 AM
Its at about 13v at the battery.
Old Sep 28, 2014 | 12:44 AM
MAD_MIKE's Avatar
MM Gruppe B
With the engine off, no accessories on, the battery voltage would be ideal to be 12.4Volts. With the engine running the voltage should be higher, closer to 14 volts but not over 14 as that would indicate over charging.
Check that your battery leads are clean and tight.
Old Oct 2, 2014 | 12:48 AM
12.5v engine off and no accessories on. 13.6v while running. Connections at battery are good.
wcsinx
Jan 16, 2019 06:12 PM
teddy_dc2
Feb 16, 2017 06:28 AM
MadVladCivic
17
Aug 18, 2013 01:59 PM
rkenyon4106
Oct 10, 2011 06:35 PM
lizp
Jan 3, 2011 04:36 PM
