Out of clue.. need serious help! car wont pass 35k rpm
Old Sep 25, 2014 | 07:15 PM
pinoysi2000's Avatar
Default Out of clue.. need serious help! car wont pass 35k rpm
honda civic si 2000 with b18c1 rebuilt fully built obd2b with obd1 ecu chipped p28 and stock p72 ecu same wont pass 3500
I have the swapped for almost 3years and out of the blue car wont pass 3500 rpm if i tried to pass it it bogged or feels like its hitting the rev limiter.
Check engine shows need o2 and map sensor and replace it and still doin same thing
NEW:
TPS
DIZZY
SPARKPLUGS/WIRES
VTEC SOLENOID/ GASKET
TIMING IS NORMAL
FUELPUMP
O2 SENSOR
tanny shift like butter
speedo works
need serious help guys thanks alot.
Old Sep 25, 2014 | 07:35 PM
NotARaCist's Avatar
I never narc'd on nobody!
Default Re: Out of clue.. need serious help! car wont pass 35k rpm
Exactly what codes are being thrown? There are multiple codes for those two components. Did you just replace the MAP sensor, or did you test it to verify functionality? After replacing those parts, is the CEL still on?
Old Sep 25, 2014 | 07:36 PM
yes cel still on and i tried my buddies omni map and its new and wont even start. 1short blink and 3 fast blinks. i had to do it in old school way
Old Sep 25, 2014 | 11:32 PM
NotARaCist's Avatar
How long of a delay is there between your 1 long and 3 shorts? You might just be throwing a 13, which would also cause your problems. Do you have a multimeter?
Old Sep 26, 2014 | 05:55 AM
tony_2018's Avatar
Fish Twig
Post video.
Old Sep 26, 2014 | 10:01 PM
hYbRid_Eg6's Avatar
Did you Check your TPS voltage?
Old Sep 26, 2014 | 10:18 PM
v8killaz's Avatar
it better not pass 35k lol.
did you clear all codes after changing map sensor. try it
boostedblue23
Mid-Atlantic
Nov 14, 2017 12:50 PM
Turbotegb20z
Apr 12, 2016 03:29 PM
Miggylowks
Feb 21, 2014 01:22 PM
Kuruptedjdm
Aug 9, 2006 09:02 PM
CHAZegHATCH
Jul 20, 2006 08:18 PM
