Out of clue.. need serious help! car wont pass 35k rpm
honda civic si 2000 with b18c1 rebuilt fully built obd2b with obd1 ecu chipped p28 and stock p72 ecu same wont pass 3500
I have the swapped for almost 3years and out of the blue car wont pass 3500 rpm if i tried to pass it it bogged or feels like its hitting the rev limiter.
Check engine shows need o2 and map sensor and replace it and still doin same thing
NEW:
TPS
DIZZY
SPARKPLUGS/WIRES
VTEC SOLENOID/ GASKET
TIMING IS NORMAL
FUELPUMP
O2 SENSOR
tanny shift like butter
speedo works
need serious help guys thanks alot.
NEW:
TPS
DIZZY
SPARKPLUGS/WIRES
TIMING IS NORMAL
FUELPUMP
O2 SENSOR
speedo works
I never narc'd on nobody!
Re: Out of clue.. need serious help! car wont pass 35k rpm
Exactly what codes are being thrown? There are multiple codes for those two components. Did you just replace the MAP sensor, or did you test it to verify functionality? After replacing those parts, is the CEL still on?
yes cel still on and i tried my buddies omni map and its new and wont even start. 1short blink and 3 fast blinks. i had to do it in old school way
CHAZegHATCH
07-20-2006 08:18 PM
