Maxing out stock feed and return.
Old Sep 25, 2014 | 04:35 PM
rico892002's Avatar
Default Maxing out stock feed and return.
I'm curious on what's the most power the stock feed (3/8) and return (5/16) will support?
I will be running 2000cc injectors. 1 Walbro 416 pump. Aeromotive regulator on e85 fuel.
Wanted a idea on what this fuel set up would max out at. Thanks.
Old Sep 25, 2014 | 05:11 PM
4drEF's Avatar
Keyboard Humorist
Default Re: Maxing out stock feed and return.
Ran across this - might help you out.
Fuel Line Sizing | Blowerworks.biz
Old Sep 25, 2014 | 05:54 PM
Charlie Moua's Avatar
My buddy made about 660whp on e85
Old Sep 26, 2014 | 06:36 AM
rico892002's Avatar
What was the fuel set up?
Old Sep 26, 2014 | 09:25 AM
Turbo-LS's Avatar
Think the most made on stock lines was about 800 on ethanol. Walbro 450 in tank and Bosch 044 inline on id2000's
Old Sep 27, 2014 | 08:24 PM
4drEF's Avatar
Keyboard Humorist
According to the article, the strength of the fuel pump is the limiting factor up until a point.
1000+ hp on stock lines with the correct pump selection >shrug< just reading.
Change the lines to make it easier on the pump.
Old Sep 28, 2014 | 04:42 AM
Muckman's Avatar
Moderator in Chief
Does the Civic Del Sol have smaller fuel lines than an Integra? (I think it does) My friend ran into a wall around 450hp on E85 with stock lines on his Del Sol. Couldnt maintain fuel pressure with a Walbro 400lph, Ev14 1600cc. Replaced FPR, eventually upgraded lines and smooth sailing.
Old Sep 28, 2014 | 05:09 PM
J.Berta's Avatar
I have a friend that made 630whp on stock civic lines/walbro 255lph/can't remember injector size(maybe 950-1000cc's) using c16. 2,000cc ' s wasn't around back then when he did this, or at least we didn't know about them...
Old Sep 29, 2014 | 08:58 AM
riceball777's Avatar
There's quite a few s2000's that are at the 700whp level on e85 with stock likes with a Waldron 400 and 2000cc injectors
Old Sep 29, 2014 | 01:39 PM
MikeySpec's Avatar
62mm B series car went 791whp(Dynojet STD) on Ignite Red which is considered E90 before i saw it leaning out. This was on the walbro 416 in tank, bosch 044 inline and grams 2000's with the base pressure cranked way high.
Old Sep 29, 2014 | 05:23 PM
V-SPEC 1's Avatar
I've tuned a friend of mine's car on stock lines using e85 ID2000 450lph and made 619whp. Pump couldn't keep up in the higher rpm range.
Old Sep 30, 2014 | 04:49 AM
boosted k20's Avatar
My fuel pressure started dropping at around 530whp with the following:
Stock Lines
Aeromotive 340lph in tank
stock regulator
1200cc injectors
Just upgraded to:
Full Blown Dual in-tank pumps
Dual aeromotive 340lph with individual relays & #10 wire
-10 Feed line
-6 return
Aeromotive A1000 regulator
same 1200cc injectors
looking to push 600+WHP
kwah
Dec 23, 2010 06:53 PM
sticest
May 5, 2009 08:21 PM
95accordh22a
Apr 20, 2006 04:22 PM
rice a roni
Feb 23, 2006 09:08 AM
cjb80
Jun 15, 2004 12:21 PM
