can i run a walbro high output fuel pump?
Old 02-23-2006, 07:10 AM
rice a roni's Avatar
Default can i run a walbro high output fuel pump?
here's the situation...
i need to replace my fuel pump and fuel return line on my crx and everybody knows its a bitch. i was thinking of going turbo so i was wondering if i could run with stock injectors and the 225lph fuel pump from walbro without making any modifications so in the future i wont have to drop the tank to drop in the fuel pump again.
Old 02-23-2006, 07:12 AM
Man U FTW
Schister66's Avatar
yeah you can do the 255lph if you want....its going to put out more fuel and allow you to up the pressure, but your stock FPR will regulate that accordingly........you shouldn't have any problems
Old 02-23-2006, 07:33 AM
Default Re: (Schister66)
ok thanks, thats what i needed.
Old 02-23-2006, 07:57 AM
Doodoo's Avatar
Default Re: can i run a walbro high output fuel pump? (0mghi2u2)
You can but it will most likely raise your base fuel pressure. You would need a FPR to lower it back to stock.
Old 02-23-2006, 08:05 AM
Man U FTW
Schister66's Avatar
i plan on installing my Walbro once it gets here and my car won't be boosted for another month and a half......
Old 02-23-2006, 08:13 AM
93supercoupe's Avatar
why do u have to replace the return line?
Old 02-23-2006, 09:08 AM
Default Re: (93supercoupe)
well one of my lines have a hole in it, its leaking like a bitch whenever i drive it so i dont know whats what first.
4drlsvt
05-28-2009 06:01 AM
iBrandon
02-17-2005 02:33 PM
snoochtodanooch
12-24-2004 03:22 PM
ATS*Mark
11-04-2003 05:11 AM
Quick Reply: can i run a walbro high output fuel pump?
