question about precision turbo
Old Sep 22, 2014 | 12:00 AM
jose5673's Avatar
Default question about precision turbo
6262jb 1000k miles on turbo. after a pull it smells like burnt oil and white smoke coming out the down pipe. took the down pipe off notice shaft play,did the turbo took a crap on me? And .65 restrictor installed
Old Sep 22, 2014 | 12:48 AM
wantboost's Avatar
Who is Mr Robot?
Default Re: question about precision turbo
white smoke is coolant
how much shaft play are we talking about?
Old Sep 22, 2014 | 07:59 AM
jose5673's Avatar
I can easily move it with my index finger the kind of play that im suprised not rubing on the housing.
Now u said coolant is white smoke ,wouldnt the resovoir get empty at times?
Old Sep 22, 2014 | 08:03 AM
AZ_CIVIC's Avatar
I personally have not run the Precision 6262 JB turbo but a friend had a brand new one on his car and it took a dump on him after less than a 100 miles. He just recently went with the 6266 and hasn't had any problems yet.
I hear a lot of good things about these turbos but just as much bad.
Old Sep 22, 2014 | 08:28 AM
viper_boy403's Avatar
White smoke can also be oil, if it's a LOT of oil. The smell would definitely be the indicator here though. Is there oil in the downpipe or turbine housing of the turbo?
With the engine off, you're going to have a bit shaft play with a journal bearing turbo. Get a little video for us
Old Sep 22, 2014 | 11:29 AM
wantboost's Avatar
Who is Mr Robot?
oil produces a smoke that has a bluish tint to it and it's a fairly thin smoke. coolant is snow white and is thick as clouds.
Old Sep 22, 2014 | 11:57 AM
light-to-moderate oil burning is blue. Heavy oil burning is white, just like coolant, and produces an equally thick smoke
Ever see a honda or subaru with broken ringlands? They smoke JUST like they're burning coolant
Old Sep 22, 2014 | 02:38 PM
wantboost's Avatar
Who is Mr Robot?
That many videos... Seriously?
Don't make me edit your post.
If the turbine seal is just starting to go it should be fairly light smoke. assuming a proper setup I find it hard to believe that a 6262 is already showing signs of failure unless the car was driven super hard for those miles.
op what's your maximum hot and cold oil pressure?
Old Sep 22, 2014 | 04:41 PM
jose5673's Avatar
Is not heavy like those videos. And it does not do it every pull . For sure mornings or if i let it sit for more than 6 hrs until it warms up is whiteish. once warm it stops. Then for example, if im driving 60mph and i down shift once the.rpms goes up to 5k it has bluish.tint wideband goes crazy even it stop reading for a minute or so
young geezer
Aug 14, 2009 02:59 PM
lookout22
May 17, 2009 07:37 PM
Lost Type R
Nov 12, 2004 12:34 PM
boostedlude3g
Apr 16, 2003 07:08 PM
4gvtec
Apr 4, 2002 05:05 PM
