another timing belt thread
timing belt snapped. d16a6. 107 tooth belt. great. got a replacement 107 tooth belt, fantastic. my problem is, this new belt is nice and snug around the tensioner/water pump, but is loose as a god damn goose crank to cam. loose to the point it WILL rub the timing cover and has enough play to potentially skip a tooth. what the hell???
you obviously didnt tension the belt properly. and its more than just how you slip it on.
you have to use loosen the tensioner bolt a couple turns, DO NOT REMOVE COMPLETELY or even get close to the end of threads.
then turn the pulley about a 1/4 turn or more.
then tighten the tensioner bolt.
