Heater Unit question
Old Sep 16, 2014 | 08:34 AM
asoRm's Avatar
Default Heater Unit question
I do not have a cable connected to #8 in the diagram which seems to be the air mix controller. Can anyone explain how the cable should connect and from what? I'd assume the Hot/Cold **** should directly impact that. Also, what connects to the heater core valve by the firwall?
#10 in this diagram, showing the cable - where does this go from the Hot/Cold ****? Something seems incorrectly lol
Old Sep 16, 2014 | 09:52 AM
Lost Again's Avatar
Default Re: Heater Unit question
Look up "blend door adjustment" for a 94 or early 95 Accord and it should show you how and where the cables run....95 1/2 and up had a different cable which no longer had the adjustment.
So you removed the cover (#3 in the first pic by removing #18) and there are no cables there?
Old Sep 16, 2014 | 10:16 AM
asoRm's Avatar
I didn't have to take a cover off (#3). It and #18 were apparently missing in action (not surprised). #8 does not have a cable connected to it.
I do see a cable still connected to the water valve going into the firewall from the engine bay.
I also see a cable from the Temp Controller which goes into the abyss behind the dash that I couldn't track at the time.
I did a search as you recommended and found this -
2) Cable #1 - This runs from the control head to the Heater Box's temperature control door actuator arm.
3) Cable #2 - This runs from the Heater Box's temperature control door actuator arm to the Hot Water Control Valve.
Going to dig more, as this still isn't something I can picture in my head yet lol
Old Sep 16, 2014 | 10:40 AM
Lost Again's Avatar
Time to "find waldo" - if the cables are at the "other ends" then they have to be somewhere.
Old Sep 16, 2014 | 12:40 PM
asoRm's Avatar
Thanks man - I am going to find Waldo tonight! lol. It looks like #3 should actually have 2 cables connecting to it. So they are hidden in there somewhere
Old Sep 16, 2014 | 01:34 PM
Lost Again's Avatar
Yes there are two cables....one from the **** to the lever, then another from the lever to the valve.
Number 10 in the two pictures are the two DIFFERENT cables.
Old Sep 16, 2014 | 07:39 PM
asoRm's Avatar
Ok so I got everything connected again. Not perfectly as I was rushing in the dark. Going to make final adjustments tomorrow or Thursday. It feels good to make progress, as little as it may be
Old Sep 17, 2014 | 03:33 PM
Lost Again's Avatar
Glad you found "waldo('s)" and were able to get them connected. If you have issues with the final adjustments let us know and we'll see if we can help.
Old Sep 17, 2014 | 04:40 PM
asoRm's Avatar
Adjusted and operational!!
I do need help to find #7, the mode motor. I find them new for 110ish. Anyone know where I could find it used? 79140-SV4-A01
Old Sep 17, 2014 | 06:10 PM
Lost Again's Avatar
On the 5th gen's....a bit of good lube on the linkage and I bet the issuer goes away,
Old Sep 18, 2014 | 07:41 AM
asoRm's Avatar
I wish - The actuating arm is missing entirely. Just the 'brick' is there.
This car making me very worried about how the previous owners lived lol
Roman Penn
Apr 7, 2017 11:03 AM
r_kage
Dec 6, 2016 10:31 AM
( o )( o )
Aug 22, 2005 04:59 PM
RotaryBzzz
Sep 3, 2002 11:18 AM
