Horn Stopped Working
Old Sep 8, 2014 | 10:10 AM
KateBeck's Avatar
Icon3 Horn Stopped Working
Hello! I have a 1994 Honda Civic LX. I bought it back in May and the horn was never that great. Sometimes the horn would go off when the button is pressed and sometimes not. The other day I was merging into traffic and someone cut me off so I pressed the horn button. It beeped and then cut out while I was still pressing the button and hasn't worked at all since. I'm not very good with cars at ALL. My dad and brother and mechanics so they'll help me, I'm just wondering what the problem is and how to fix it.
No mods, original steering wheel.
Old Sep 9, 2014 | 09:31 PM
SuppDude1's Avatar
Default Re: Horn Stopped Working
Horndied or the metal connection behind the steering wheel has come loose.
Old Sep 10, 2014 | 04:14 PM
KateBeck's Avatar
How can I test if the horn died? And if it's not the horn how can I fix the connection in the steering wheel?
Old Sep 10, 2014 | 04:20 PM
NotARaCist's Avatar
I never narc'd on nobody!
Could also be the horn relay, or the wiring. Start off by using a voltmeter to see if you get voltage to the horn with a friend pressing the button, and if you don't, keep working your way down the wire until you find the bad piece.
Old Sep 10, 2014 | 04:34 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
If you want to test if the horn still works or died, unplug the 2-wire electrical connector to the horn. Then using a spare piece of jumper wire (like speaker wire), put one end of the jumper wire into the cavity of the connector where the Blu/Red wire is. Plug the connector with the jumper wire back into the horn. Then touch the other end of the jumper wire to body ground (metal) or the negative battery terminal. The horn will sound if it is okay.
Blu/Red is a wire with blue colored insulation and a red stripe running through it. This is the ground wire.
The horn suppose to always receive power/voltage (+) at all times from Under-hood Fuse No. 42 (20A) via the Wht/Grn wire. It just needs the ground (-) source to make the horn sound, which is controlled by the horn switches.
Old Sep 10, 2014 | 06:13 PM
SuppDude1's Avatar
That's right. And to get under the steering wheel there are just about 4 Philips screws on the backside of the wheel.
Old Sep 11, 2014 | 10:37 AM
KateBeck's Avatar
When I press the horn buttons I hear a click from the front like it's trying to do something so I'm guessing it's not the buttons themselves.
Old Sep 11, 2014 | 10:48 AM
tech8's Avatar
Global Moderator
Loved
Community Favorite
The click you're hearing is probably from the horn relay; so, the issue is probably not the horn switches and steering wheel area. Also horn relay may be good due to click.
vroomeo
Feb 20, 2010 08:12 PM
zman
Oct 29, 2008 09:06 AM
2k3msp
Jun 23, 2008 10:26 AM
fms1day
13
Nov 28, 2006 02:05 AM
ejprimo
May 22, 2002 01:31 PM
