89 Civic Si fuel pump not working!
Old Aug 31, 2014 | 08:14 AM
Steenracing's Avatar
Default 89 Civic Si fuel pump not working!
Hello i have a 89 civic si and my fuel pumps not priming. 1st My main relay is good clicks when key is turned on, @2nd checked all fuse's and every one is good,3rd All grounds are good,4th I checked the connection that the pump plugs into and I'm getting a reading of 7.5volts W/ a semi drained battery. also the car had the pump replced with a walbro 190lph about 10 years ago . Do you guys think the pump is bad?? Any help is appreciated.
Old Aug 31, 2014 | 10:12 AM
woodenchef's Avatar
Default Re: 89 Civic Si fuel pump not working!
Well if your getting power to your fuel pump and it still is not priming when the key is in and you said your main relay is good. Then bam you solved you own problem replace the fuel pump. If you have power there and all the electrical is working your fuel pump SHOULD work. 10 years also the fuel pump is probably pretty old by now. I'd start there.
Old Aug 31, 2014 | 10:35 AM
Ok thanks wasnt sure if it could be anything else didnt want to have to drop tank hehe
Old Sep 22, 2014 | 02:51 PM
UPDATE!! Replaced fuel pump and still nothing, i have to pm6 computers ive tried and nothing anybody have any ideas ??
Old Oct 3, 2014 | 08:21 AM
Bump anyone? ... I really cant find the thermostat ground anywhere .... idk if its because the swapped motor (dohc zc) but any suggestions would be appriciated.
Old Oct 3, 2014 | 09:19 AM
jlicrx's Avatar
Old Oct 3, 2014 | 10:59 AM
Found it , looked good .. id like to say again im getting power to the connector where the back seat would be ... so could the wiring going to fuel pump be bad ?
Old Oct 4, 2014 | 06:38 PM
Bump!
Old Oct 5, 2014 | 08:16 AM
Bump really trying to get this going
Old Oct 5, 2014 | 09:02 AM
jlicrx's Avatar
which connector are you checking? - 5-pin or 2-pin?
Old Oct 6, 2014 | 11:30 AM
I couldnt tell you off hand ill find a diagram and get back to you ... if you dont mibd me asking whats the difference ?
Old Oct 7, 2014 | 08:55 AM
jlicrx's Avatar
the 5-pin connector has the wiring for the pump - the 2-pin connector has the wiring for the gauge sending unit - you could have power for the gauge sending unit and have no power for the pump
Chris del sol
Apr 16, 2013 10:42 PM
zippakilla
Feb 6, 2009 04:01 AM
GDM S2K
Honda S2000
Jan 8, 2007 01:30 PM
93FlatBlackHatch
Dec 30, 2006 03:22 PM
ill phil
Apr 23, 2003 11:58 PM
