D16/z6 minime swap from d16y5
Old Aug 29, 2014 | 10:23 AM
D16/z6minime's Avatar
Default D16/z6 minime swap from d16y5
Recently picked up a z6 head and I wanted to know if a p28 obd2a ecu will work with it. I currently have the d16y5 in my 98 hx. I know it's a obd2 ecu that runs the vtec-e. Does anyone know any write ups on this swap or the y5 to y8 swap that's similar? And a part list for the wiring would be great too! The guy wants 60 for the chipped p28 but I want to make sure it will work first
Old Aug 29, 2014 | 10:51 AM
Former User's Avatar
Default Re: D16/z6 minime swap from d16y5
Please click on the FAQs sticky.
Old Aug 30, 2014 | 03:15 AM
HondaPartsHero's Avatar
Technical Hero
If its an OBD2 P28 its not chippable. Also if you use the Z6 head the closest ECU to use is the OBD1 P28. If you use either ECU you'll have to convert from a 5 wire 02 to a 4 wire. The rest should be plug and play.
2dr CRX
Jun 4, 2013 11:45 AM
jdm89crxhf
Jan 17, 2013 10:16 AM
Deviant117
Jan 26, 2011 08:41 AM
MikeyL513
Mar 30, 2010 08:31 AM
HatchMo
Aug 31, 2005 09:40 PM
