Thermostate housing + aftermarket temp sending unit?
Old Aug 27, 2014 | 05:35 AM
Charlie Moua's Avatar
Default Thermostate housing + aftermarket temp sending unit?
I would like to drill/tap into thermo housing to install 1/8' npt temp sending unit. The tap location with most clearance is the round "waterneck" inlet.
Q:
1) Would the cast alumunim of the thermo housing inlet be thick enough to drill/tap, or is it too thin & no allowing for enough treads.
2) Has anyone done this modification?
Old Aug 27, 2014 | 08:47 PM
slowcivic2k's Avatar
Default Re: Thermostate housing + aftermarket temp sending unit?
What car are you working on? Pics of the prospective site would help.
Old Aug 28, 2014 | 03:06 AM
sixstroke's Avatar
I would TIG on a bung.
Old Aug 28, 2014 | 05:41 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
It isn't technically thick enough. It can be done if you make sure to only run the tap partially down. Since everything is tapered the further you run the tap the further you need to thread the sensor. With all that being said you run a very high risk of leaks and cracking the housing. Only try it if you have a spare housing to experiment with. Otherwise you best bet is to weld a bung.
ram1107
Classic Hondas
Dec 11, 2012 07:06 PM
TPB
10
May 14, 2006 11:56 AM
94GSRRacer2
Apr 29, 2002 06:22 PM
JM Performance
Mar 25, 2002 10:27 PM
