Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Installing Autometer water temp sensor
Old May 7, 2006 | 04:16 PM
TPB's Avatar
TPB
Default Installing Autometer water temp sensor
I'm wondering what methods people have used to install their water temp sensor (I have an Autometer electric temp gauge btw). I'm toying with two alternatives:
1) Remove the ect switch and with the aid of an npt adaptor, install the temp sensor in its place
2) Find a rad hose adaptor that can accomodate the 1/8" npt sensor
I'd appreciate any feedback as I'd like to complete this last job on my car before the race season begins next weekend
edit - I forgot to mention that this is for a DC2
Old May 7, 2006 | 04:52 PM
xerox445's Avatar
Default Re: Installing Autometer water temp sensor (TPB)
I drill and tap the neck of the coolant exit on the head with a 1/8th npt tap. Put a bit of honda bond on the threads and screw it in, clean and leak free install. I'll snap a pic tomorrow if I get a chance.
Old May 8, 2006 | 03:50 PM
APEX CRX's Avatar
you can also buy a Blitz upper radiator hose with a small outlet for a sensor to clamp into. Easy to install and reverse
Old May 8, 2006 | 05:05 PM
TeamNextGenChris's Avatar
i don't think you'd want to remove the stock coolant temp sensor,as on the OBDI+ cars,isn't that only one?the ECU still needs a water temp reference.
either T off the stock location and keep the stock sending unit,or drill and tap somewhere else.
Chris
Old May 9, 2006 | 02:56 AM
TPB's Avatar
TPB
Default Re: Installing Autometer water temp sensor (TeamNextGenChris)
Sorry, I didn't make myself clear - I'm keeping the ect switch but replacing the ect sensor. It's a '97 itr but has a p72 chipped ecu with obd-1 conversion harness. Do you foresee a problem with this set up?
Modified by TPB at 4:17 AM 5/9/2006
Old May 9, 2006 | 05:40 AM
TPB's Avatar
TPB
Rather than risking throwing cel's I decided to have an adaptor fabricated and just mount the sensor in there. Not sure if the adaptors are difficult to come across in the US but in Canada few if any places regualrly stock them.
Old May 9, 2006 | 07:09 AM
johng's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by George Knighton &raquo;</TD></TR><TR><TD CLASS="quote">
We are not to allow the deliberate promotion of rival sites in posts, although it's logical to assume that there might be occasional legitimate cause to refer to data on a rival site.
Since George said that, I'll assume it's okay to link to a rival site for more helpful data on this subject.
http://www.roadrace-autox.com/...art=1
Old May 9, 2006 | 10:12 AM
TPB's Avatar
TPB
Default Re: Installing Autometer water temp sensor (johng)
Thanks johng - that's pretty much what I'm doing!
Old May 9, 2006 | 05:22 PM
EleanoR's Avatar
http://www.greddy.com
Go to electronics and then to gauge accessories. I bought the 32mm adaptor for my Autometer electrical water temp gauge. I tapped into the upper radiator hose and that is where the sender goes. We then wired a ground as well as a 12v lead and voila the temp gauge is functional.
We did have to re-tap the adaptor for the Autometer fitting to fit correctly without leaks. That wasn't a problem. One last thing, make sure there is a ground from the gauge (per directions from Autometer) as well as a ground from the adaptor itself to a good ground source. We finally figured that the gauge wasn't working because the adaptor needed a grounding source to read correctly.
This was how we did it. There are a number of different ways but this was one quite simple to achieve what we set out for. Good Luck!
Old May 9, 2006 | 06:07 PM
TPB's Avatar
TPB
Default Re: Installing Autometer water temp sensor (EleanoR)
Interesting EleanoR. I'll make sure I ground the adaptor in case I don't get a reading. Thanks for the tip!
Old May 14, 2006 | 11:56 AM
VTECAcuraGSR's Avatar
I have my sender upper radiator hose adaptor for sale. if you still need this let me know.
punkracer
Jul 4, 2010 06:55 AM
h-t sucks
Aug 5, 2005 05:09 PM
JM Performance
Mar 25, 2002 10:27 PM
seanb18c1
Feb 12, 2002 04:55 PM
