P28 ECU or P08??
Old Aug 27, 2014 | 12:04 AM
tgordenDELSOL's Avatar
Icon2 P28 ECU or P08??
Hey guys i bought a del sol with a JDM D15B vtec swap in it. The guy had a P28 ecu in it. But i read online that the P08 is supposed to be for this engine. Will it really make a difference keeping the P28 that's already in it? Or should i just swap it out for a P08?
Old Aug 27, 2014 | 06:00 AM
spAdam's Avatar
Loved
Community Favorite
Default Re: P28 ECU or P08??
Good luck finding the P08 ecu. You should be running it though to run the motor properly. There are a few threads around the internet (saw one on desires.org recently) where people are making it work with other means.
Old Aug 30, 2014 | 05:20 PM
94EG8's Avatar
Seagull Management
There's not much difference in the fuel and timing maps as far as I can tell. The biggest difference is that a P08 is meant to use a single wire unheated O2 sensor.
For what it's worth I ran that engine with a P28 for 5 years and it always ran perfectly and got excellent fuel mileage.
Old Aug 30, 2014 | 10:41 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
If I may inquire, where are you finding the fuel and timing maps for the various ECUs? In all my searches I have never found any sort of repository for that valuable information.
Old Aug 31, 2014 | 03:08 AM
94EG8's Avatar
Seagull Management
I'm not. But you're looking at two engines that share the same head, cam, valve train, etc with a very, very similar bottom end. The maps aren't going to differ significantly.
You could go to pgmfi.org and find the .bin files and open them in crome and take a look at them though. Also, some of the differences you do find will be for differences in elevation and such between here and Japan.
GERBERBOII
Mar 17, 2010 02:27 PM
l1bid0
Apr 15, 2007 05:43 PM
CivicHP
May 11, 2006 10:54 AM
trooper0641
Sep 13, 2004 07:37 PM
TABIAS
13
Nov 4, 2003 12:39 PM
