95 integra b18b1 turbo project need help
First question for colder plugs will zfr6f-11 plugs work from ngk? Stock is zfr5f something i believe..and any suggestions for tuning? And will my stock fuel punp be ok?
Dont be a sourpuss.i realize i didnt put much info thats my bad..only gonna run 7psi some say stock fuel pump is ok but im not gonna risk it, got a wahlbro 255lph..and my spark plugs are perfect, thanks, injectors everything else is squared away, gonna leave stock map sensor in for now unless i up the psi..but tuning, its an automatic b18b1 95 integra special edition with a p75 ecu, yes i know auto tranny is no good but ima run it till it blows, just what i choose to do..i can get a basemap chip but to fine tune it afterwards what program or system? Hondata doesnt support automatic
Who is Mr Robot?
None of the OBD1 chipped ecu softwares support autotragics.. at least not the last time I checked.
if you have a separate tcu then you're fine but if you don't, well... you're screwed.
Spawne32 tried with all of his might to get a jrsc ls to run a built Honda auto trans and it never worked out despite multiple attempts.
Herycykj
Engine Management and Tuning
22
Oct 15, 2014 11:17 AM
