ECU guru's help!
Old Dec 29, 2004 | 09:56 AM
Type Wah's Avatar
Default ECU guru's help!
I have a p70 ecu for an obd1 integra auto, the dude I bought it from says it will fit my 95 integra ls auto. Can anyone confirm this? I went to hondata.com and they dont list p70
please help
Old Dec 29, 2004 | 10:07 AM
Type Wah's Avatar
if its not an ecu off a 95 auto ls, would it still work with my car?
I had an old harness from an auto ls and it plugs right into this ecu i bought, so i'm assuming it should work, but i need to be certain!
Old Dec 29, 2004 | 10:19 AM
dustrag's Avatar
yep it works.. both obd1 and both auto.. good match
Old Dec 30, 2004 | 11:37 AM
Type Wah's Avatar
Default Re: (dustrag)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dustrag &raquo;</TD></TR><TR><TD CLASS="quote">yep it works.. both obd1 and both auto.. good match</TD></TR></TABLE>
just double checking to make sure, I searched and it shows that the p70 ecu is for 92-95 domani's with no zc vtec oil pressure, will this work with my 95 auto LS, like would it have the same ignition map or whatever it needs to run?
Old Dec 30, 2004 | 11:46 AM
Kendall's Avatar
If it is indeed an OBD-1 automatic ECU, then the car will start, but how well it runs can't be determined until you actually try it. Odd's are it's tuned a bit differently and it'll hurt performance.
Old Dec 30, 2004 | 11:48 AM
Type Wah's Avatar
Default Re: (Kendall)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall &raquo;</TD></TR><TR><TD CLASS="quote">If it is indeed an OBD-1 automatic ECU, then the car will start, but how well it runs can't be determined until you actually try it. Odd's are it's tuned a bit differently and it'll hurt performance.</TD></TR></TABLE>
Yeah its obd1 since the harness off my old ls ecu plugs right in, I just need it to run so I can trade the bastard in for a car that is more reliable right now. This car broke down on me 3 times already
Old Dec 30, 2004 | 11:55 AM
Curtisbeef's Avatar
that ECU is for a 92-95 OBD1 Domani and i have no idea what that is....
Old Dec 30, 2004 | 11:56 AM
Type Wah's Avatar
Default Re: (Curtisbeef)
I believe its a civic with a acura el front end conversion popular in canada LOL
civic_jason
Jan 24, 2013 08:45 AM
scooter
May 18, 2006 06:39 AM
projectTeG
Dec 20, 2005 04:23 PM
TEG777
Jun 2, 2005 07:02 PM
