more or less grease on prise axel
Hi guys
How much grease do i need to put on the axel on the gearbox that goes into the clutch ?
I also did some grease on the inside of the release bearing and the shaft.
Also a little in the ball joint in the clutch fork.
But i need some confirmation that its done good or bad seeing the picture below.
And tips are always welcome !
Thnx you hondafolks
Thnx you hondafolks
light to none.
I messed up a twin plate clutch a few years ago by putting too much grease on it which basically a really light coat. the grease ran down to the clutch plates and messed them up.
put a light coat on and wipe it off.
Thnx for the answers.
I think i did a little to much grease on the axel.all between the splines are full of grease.
Schould i also pit some grease on the inside ring of the clutch ?
Greetz en thnx guys !
when I install I usually use lite coat of lithium grease, on the bearing shaft, and on the tips of the fork really really lite.
where in Germany are you? ask me how I know?
Hey rudebwoy !
Thnx for your replay !
I dont life in Germany ,but i think that you see the high temp grease haha
i life near Germany ,in the Netherlands !!
only put grease on the bearing shaft, very thin coat like when you lotion your hands.
Thnx rudebwoy !
yess i know sneaky tuning !
and i heard of dp but dont know who that is
i did al little to none grease where the splines are (like you lotion your hands)
and i did it a little on the bearing shaft
do you mean the bearing shaft like where the bearing moves up and down when you press the clutch pedal ?
sorry for my bad engilish and i epriciete your help verry much !!!
Thnx rudebwoy !
Super79Dave
17
Apr 22, 2011 07:46 PM
