Cruise Stumble S300
Old Aug 16, 2014 | 12:28 PM
donivan_p's Avatar
Default Cruise Stumble S300
New to tuning but figure I would give it a stab at it.
I have a B18C5 with JRSC. Professionally tuned January but I have a small part throttle cruise stumble and AFR sweep that gets on my nerves.
As far as the Stumble, from my research and what I can tell from my datalogs, I have a close loop issue.
Problem appears during cruise, around 8% throttle and 4k RPM, Short fuel term trim usually sweeps from -3% to -16% then goes flat at 0% for a second which then the TPS flatlines causing the Injectors to cut out which is the stumble. Everything picks back up after that for another minute or so.
Second issue: Air to Fuel sweeps from 13.3 to 16.8 within seconds. Enough to make you feel seasick. ha
Any initial Ideas?
Last edited by donivan_p; Aug 17, 2014 at 08:29 AM. Reason: Clearing up the issues
Old Aug 17, 2014 | 04:39 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: Cruise Stumble S300
You focus more on the AFR change in your description instead of the stumble. So by going off the information given - it is perfectly normal for the AFR to read lean upon closing the throttle plate with deceleration. Are you trying to say you have a stumble while driving or problems with tip-in after closing the throttle plate and reopening it? OR do you mean everything is flatlining without you changing throttle position while cruising?
Old Aug 17, 2014 | 06:39 AM
donivan_p's Avatar
Sorry for the confusion. Two different problems. Afr sweep is at light throttle. I figure the rate of change should be less drastic..
The stumble is from the flatline without changing throttle position. Usually at parking lot speed or at cruise. I can see it in the datalogs, short term fuel trim goes and stays at +1% then tps flatlines causing injectors to cut out. All of this at cruise, 80mph around 8% throttle & 4k rpm.
Old Aug 17, 2014 | 07:17 AM
donivan_p's Avatar
This is some photos I have of the stumble at cruise.
First the noticeable symptom. Fuel cut from tps flatlining but is at cruise so throttle should stay around 8%.
So I thought TPS or wiring but then I looked at Closed Loop (second photo)
Short term fuel trim levels out at 0% before the TPS flatlines.
I checked all the calibrations for closed loop and it all matches what Hondata recommends.
Hope this clears up any confusion.
Old Aug 19, 2014 | 09:18 AM
donivan_p's Avatar
Default What does a bad O2 sensor look like on graph?
Looking at the second chart. It appears the problem is caused from the bad O2 sensor or a short term fuel trim issue.
What does it look like?
BTW- From what I can tell my AEM wideband gauge never stops sweeping until the fuel cut.
2x0
Engine Management and Tuning
11
Jun 22, 2018 08:12 PM
platinum00
Dec 12, 2006 01:13 PM
turboteg2nv
Nov 28, 2005 10:29 PM
blackdude
Nov 19, 2004 03:37 PM
Kp_VtekNiks
May 24, 2004 10:29 AM
