Hardrace Engine Mounts D15Z1
Old Aug 14, 2014 | 08:04 PM
Farlander's Avatar
Default Hardrace Engine Mounts D15Z1
Replaced all the engine mounts on my '94 VX with hardrace hardened rubber mounts. Had to press in the driver side mount because the bracket was wrong.
The car shakes like crazy inside now. Barely able to tolerate the rattle noise inside the car. Car is louder outside too, panels rattling and everything. Any advice? Do these things just suck that much? My old mounts weren't that bad they were just old and the lower driver side was constantly broken...
I'm thinking of trying to use pieces of radiator hose as insulators between the bolts and the mounts...
Old Aug 14, 2014 | 08:14 PM
eHMxhACk's Avatar
yippee-ki-yay
10 Year Member
Default Re: Hardrace Engine Mounts D15Z1
Did you do any research on stiffer engine mounts prior to installing them? From what I've read and understand the vibrations/shakes/rattles/noise you're feeling are a result of the stiffer mounts, especially with respect to Hasports mounts. I would expect the same result using Hardrace mounts.
LINK
LINK
LINK
Post #11 is from a well respected member here.
eH.
Old Aug 14, 2014 | 08:17 PM
tony_2018's Avatar
Fish Twig
Once you break them in you'll be fine.
JBLAZE622
Dec 19, 2008 08:24 AM
Poroshok
Jul 16, 2007 07:12 PM
92 CIVIC HATCH VX
Nov 11, 2005 10:28 AM
dub204
Jun 8, 2004 10:17 AM
vtecmike1
Nov 19, 2003 07:19 AM
