civic ek rear brake conversion
haloo guys
I want swap the rear brake on my ek 96 from drum to disc and I have couple of questions....
1. if i have rear eg6 break with TRAILING ARM do i have install all or only the SPINDLE
2.after the Convert do i have change the Brake Booster to 1" Master Cylinder
or the stock one is working good
thanks
thanks
Well all you need to swap is the spindles and hubs. But im not sure if a EG6 rear brakes will work on a 96-00 civic. I know you need the e-brake cables of an 99-00 SI to make it work properly. Your stock master cylinder will work just fine for it.
Romo Pyro
21
Jan 19, 2010 06:13 PM
Ek9andyroo
Sep 9, 2009 12:42 AM
Ya@inlinePRO
Mar 14, 2002 11:41 AM
