Possible to Replace A/C Thermostat without Removing Evaporator?
Old Aug 12, 2014 | 11:14 AM
JimRaynor90's Avatar
Default Possible to Replace A/C Thermostat without Removing Evaporator?
Do i need to replace the a/c thermostat to have my a/c working? it only works when i jump it and i read that it should only be a temporary fix, everything works good the a/c thermostat is the only thing wrong
Old Aug 13, 2014 | 04:26 PM
slowcivic2k's Avatar
Default Re: Possible to Replace A/C Thermostat without Removing Evaporator?
Short of destroying your case to remove it, you will need to remove the evaporator housing to replace it. It must be clipped in the evaporator in order for it to function as designed.
Old Aug 13, 2014 | 07:23 PM
holmesnmanny's Avatar
The thermostat wraps around the coils. Its physically impossible to remove it w/o pulling the evap.
Instead, replace the expansion valve and call it a day.
charosenz
Honda Civic (2006 - 2015)
Mar 6, 2017 08:45 PM
vinuneuro
Sep 10, 2013 05:56 PM
jdm-ek-si
Mar 31, 2009 04:15 PM
EF7
Apr 22, 2008 04:41 PM
