What is the cc on Type R injectors???
Old Oct 31, 2002 | 02:13 PM
B20Coupe's Avatar
Default What is the cc on Type R injectors???
i hear that all b-series injectors are 240cc so...i was wondering if the type r ones are any different??? thanks for the help!!!
Old Oct 31, 2002 | 02:14 PM
RTW DC2R's Avatar
Default Re: What is the cc on Type R injectors??? (B20Coupe)
same
Old Oct 31, 2002 | 02:18 PM
CivicEK.PDX's Avatar
Default Re: What is the cc on Type R injectors??? (RTW DC2)
BUT the B-Series VTEC injectors have a WAY different tip resulting in BETTER spray.
Old Oct 31, 2002 | 02:21 PM
sgT's Avatar
sgT
Default Re: What is the cc on Type R injectors??? (CivicEK.PDX)
heh. you SURE about that?
Old Oct 31, 2002 | 02:24 PM
Austin's Avatar
Default Re: What is the cc on Type R injectors??? (sgT)
They're better because they came on the Type-R...I ditched mine and decided to use Prelude injectors instead.
Old Oct 31, 2002 | 02:25 PM
sgT's Avatar
sgT
Default Re: What is the cc on Type R injectors??? (Austin)
Type-ARRRRR Captain
Old Oct 31, 2002 | 03:02 PM
ZygSpeed's Avatar
Type-ARRRRR Captain
LOL!
small letters req.
Old Nov 1, 2002 | 07:32 AM
01ITR#700's Avatar
Default Re: What is the cc on Type R injectors??? (Zygspeed)
I've asked this in the forced induction forum, but I was just curious as to how large of injectors can be ran by the stock Type R ECU? Would it be able to idle 370cc injectors? Larger? Smaller?
Thanks for any info.
M
Old Nov 1, 2002 | 09:07 AM
R you serious's Avatar
Default Re: What is the cc on Type R injectors??? (01ITR#700)
id get a bigger fuel pump for that
Old Nov 1, 2002 | 09:52 AM
Austin's Avatar
M
With an AFC, or a VAFC you can get the car to idle with the 370's...check in the Forced Induction forum for more information...the ECU has a certain amount of a correction factor that it can apply to the injector duty cycle to reduce the amount of fuel that is being spit into the cylinders.
Austin
Hayaimoto
Mar 29, 2005 01:45 PM
nholmes
Jan 10, 2005 08:13 PM
oday
Aug 6, 2003 02:10 PM
LSturboHB
Jan 3, 2002 07:28 PM
