SKYLINE INJECTORS on bseries???
Old Mar 23, 2005 | 09:13 AM
Hayaimoto's Avatar
Default SKYLINE INJECTORS on bseries???
Just curious but has anyone put skyline injectors on a obd bseries powerplant before? I got some news from a friend in Japan that supposedly did it. He used 440cc R32 injectors on the bseries. Just curious if anyone has done it before stateside? thanks guys. However my buddy over there wouldnt give me any heads up info on how to do it
Old Mar 23, 2005 | 09:21 AM
Hayaimoto's Avatar
Default Re: SKYLINE INJECTORS on bseries??? (JDMerzxCEO)
Bump it up?
Old Mar 28, 2005 | 02:24 PM
Hayaimoto's Avatar
ttt?
Old Mar 28, 2005 | 03:11 PM
Rtype16's Avatar
Aren't they side feed injectors?
Old Mar 28, 2005 | 03:50 PM
im_poor's Avatar
Default Re: SKYLINE INJECTORS on bseries??? (Rtype16)
would this be more cost effective? not sure why someone would do this. enlighten me.
Old Mar 28, 2005 | 04:20 PM
_BEN_'s Avatar
Default Re: SKYLINE INJECTORS on bseries??? (im_poor)
Not trying to be cocky.
But where do you plan on finding these injectors. The skyline is a pretty rare car around these parts.
Old Mar 28, 2005 | 04:38 PM
Hayaimoto's Avatar
Default Re: SKYLINE INJECTORS on bseries??? (_BEN_)
I have all six of these injectors in my hand. they are top feed injectors, all i know is that my friend took them off his gtr32 (rb26) and shipped them to me. They look like mitsubishi injectors also. But they are 440cc injectors, they are low impedence. I wanted to know if they are saturated type or peak and hold type. Im doing as much research as i can because at about 65-70psi fuel they will be around 550cc's! thanks guys any help would be greatful
I just test fitted the injector clips from a stock obd1 gsr harness and it doesnt fit so it looks like i will need to find sr or rb injector clips also.
Modified by JDMerzxCEO at 5:48 PM 3/28/2005
Old Mar 28, 2005 | 04:57 PM
_BEN_'s Avatar
Maybe give motorex a ring. They may be able to answer your questions.
Old Mar 28, 2005 | 05:35 PM
rjay8604's Avatar
if they are low impedence then they are peak and hold, they are the same thing.
Old Mar 28, 2005 | 06:12 PM
im_poor's Avatar
Default Re: SKYLINE INJECTORS on bseries??? (rjay8604)
to check peak and hold, and saturated, check the for ohms/resistance w/ voltmeter.
Old Mar 29, 2005 | 12:40 PM
Hayaimoto's Avatar
well isnt peak and hold for older car models? saturated is for later cars correct?
Old Mar 29, 2005 | 01:34 PM
im_poor's Avatar
just do what i said and you will know for sure.
Old Mar 29, 2005 | 01:45 PM
Hayaimoto's Avatar
how many ohms is it suppose to be?
D.B.ate
Apr 23, 2017 06:04 PM
joeybuilt
Dec 17, 2013 07:40 PM
HondataB18
Sep 24, 2012 05:09 PM
alx_90ef
May 4, 2009 03:55 PM
Jasper_db1
Sep 26, 2006 07:40 AM
