can some run through the steps on dropping a tranny
Old Oct 31, 2002 | 02:08 PM
TeAm IllUsIonZ978's Avatar
Default can some run through the steps on dropping a tranny
I need to drop my tranny asap because im get my new one on sat..Thanks
Old Oct 31, 2002 | 02:25 PM
ransack's Avatar
Default Re: can some run through the steps on dropping a tranny (TeAm IllUsIonZ978)
ummmm what do you have?
Old Oct 31, 2002 | 02:26 PM
Default Re: can some run through the steps on dropping a tranny (ransack)
i have a B16 motor and tranny
Old Oct 31, 2002 | 03:10 PM
Kamin's Avatar
jack car up (secure on jackstands)
take front wheels off.
disconncet battery
remove 4 upper bolts on transmission
disconnect VSS and starter cables.
remove the starter
take out the clutch slave cylinder
disconnect o2 sensor from connector
remove header
remove the axles
remove the engine stiffener brackets. (2 of them)
remove the flywheel cover
revome shift linkages.
remove the 2 lower bolts that hold the transmission to the block.
secure the engine, i put a jack under the oilpan with 2 blocks of wood
secure the transmission to somthing, i.e. a transmission jack.
disconnect the transmission from the tbracket (rear mount)
disconnect the upper and lower transmission mounts
put a flathead screwdriver between the block and the transmission and gentlly pry.
lower on transmission jack that was placed under it.
that should be about it, if i missed somthing let me know.
its harder than i made it sound
if you have never done this before, buy a helms...
[Modified by KAMiN, 4:11 PM 10/31/2002]
[Modified by KAMiN, 4:19 PM 11/1/2002]
Old Oct 31, 2002 | 09:26 PM
Farnsrocket's Avatar
Default Re: can some run through the steps on dropping a tranny (KAMiN)
you forgot all of the swearing involved, especially when putting it back in.
Old Nov 1, 2002 | 06:35 AM
racerxadam's Avatar
shift linkages?
Old Nov 1, 2002 | 06:41 AM
94CivicSi's Avatar
Default Re: can some run through the steps on dropping a tranny (racerxadam)
shift linkages?
And get a new compression pin to replace the old one.
You don't have to remove the axles. Just pull the shock assembly out, separate the LCA from the hub, pop the axels out of the box and swing them out of the way. (I think this is what Kamin meant, I just wanted to clarify before you fight the 32mm nuts)
Old Nov 1, 2002 | 02:44 PM
ransack's Avatar
Default Re: can some run through the steps on dropping a tranny (94CivicSi)
see sig
dont forget that one
other then that, everything above seems correct.
dont forget proper torque for the bolts. and fluid.
Old Nov 1, 2002 | 03:19 PM
Kamin's Avatar
shift linkages?
oh yea
duh.
arielb1
Oct 31, 2008 12:03 PM
B18CYAAA
Oct 11, 2008 07:11 PM
IMSTOCK
Dec 2, 2005 04:46 PM
0ptimus prime
Jul 17, 2004 11:17 PM
jovial111
Dec 22, 2003 08:23 PM
