Suggestion for What Oil Weight to use
Old Aug 9, 2014 | 03:34 PM
marcs23's Avatar
Default Suggestion for What Oil Weight to use
I have a B20 block with a GSR head. The Block is built. The head is stock. I have a T3/T4 turbo and it was recently tuned on hondata on 11psi making 301HP and 245 Tq. I am due for an oil change and I would like to know what suggestions should I use. Obviously synthetic. I live in FL so I was thinking 10w40 in the summer and 10w30 in the winter. This will be my first oil change on this set up. thanks
Old Aug 9, 2014 | 03:55 PM
Turbo-LS's Avatar
Default Re: Suggestion for What Oil Weight to use
Who built the motor? They should've provided bearing clearence and recomendations on what weight oil you should be running.
I don't like to run anything less than valvoline VR1 racing oil but that was years ago. I personally run Joe Gibbs XP6 oil in my car. But it's not a street car
Old Aug 9, 2014 | 04:09 PM
marcs23's Avatar
The previous owner had the block built so I am not sure about bearing clearance. The previous owner told me he ran 10w30 or 10w40 but if he ran it hard, he would use 20w50. All of these were synthetic. This is not my daily driver and I need to do an oil change and Not sure what I should use. The motor was built a little over a year ago. thanks
Old Aug 9, 2014 | 05:34 PM
Turbo-LS's Avatar
What kind of oil pressure are you seeing with 10w30?
Old Aug 9, 2014 | 07:12 PM
ls joker's Avatar
Loved
my input is vague. but i basis my oil off of oil pressure and bearing clearances
Old Aug 9, 2014 | 08:57 PM
marcs23's Avatar
I do not have an oil pressure gauge. I do plan on getting one.
anyone else?
Old Aug 10, 2014 | 07:59 PM
F22Master's Avatar
Rotella T6 is always a good choice. It only comes in 5w40, but that should be fine for you. It also has plenty of good additives that your turbo and engine will love lol
Until you get an oil pressure gauge you will really never know.
Old Aug 11, 2014 | 01:27 AM
4tika4's Avatar
rotella t6 here too
Old Aug 11, 2014 | 07:02 AM
marcs23's Avatar
thanks everyone
Old Aug 11, 2014 | 08:03 AM
boostjunkie757's Avatar
i run 5w30 synthetic in mine.
Old Aug 11, 2014 | 10:06 AM
$amGD3's Avatar
Swaggylicious
Running Rotella 15-40 here because 1.cheap 2.decent reviews 3. needed a thicker oil due to old motor
Old Aug 12, 2014 | 08:00 AM
speedjunkie_g35's Avatar
From: Pensacola, FL and every Court House in Louisiana
I use the same.
Old Aug 12, 2014 | 06:53 PM
welfarepc's Avatar
I think VW did a goob job figuring out what oil to run so it lasts.
5w40 synthetic. All day, err day.
With that being said, I run Rotella 15w40 in summer and dont drive it in the winter. But if I did have to drive in winter, 5w40 so it gets up and around the engine quicker when cool VS a 15 weight.
Old Aug 13, 2014 | 12:37 PM
Aradin's Avatar
Premium Member
+1 for the Rotella. Been using the 15w40 conventional since I built my motor a couple thousand miles ago, also previously used it on a stock block setup. Planning on switching to the T6 next oil change. My dad also swears by the stuff and uses the 10w30 Synthetic blend in almost every piece of farm equipment and all the vehicles he has. I noticed this stuff is very resistant to thermal breakdown and excessive high temperatures as compared to some other conventional oils I tried like Pennzoil, Valvoline, etc.
Old Aug 15, 2014 | 06:13 AM
DA 4 Lyfe's Avatar
I use 10w40 Brad Penn
Old Sep 16, 2021 | 01:01 AM
james8's Avatar
rotella t6 prefered here too
Old Sep 16, 2021 | 07:38 PM
Tunerbuilder's Avatar
Rotella T6 seems to be a reliable go-to for what I've run.
90Rexx
Apr 28, 2008 06:42 AM
turbochargeb18c
Jun 18, 2005 04:20 PM
Mr. JDM-GSR
Mar 29, 2004 02:14 PM
ALL MOTA
May 1, 2003 09:20 PM
crxhybrid1320
Feb 7, 2003 05:22 PM
