Suggestion for What Oil Weight to use
Old 08-09-2014, 03:34 PM
marcs23's Avatar
Default Suggestion for What Oil Weight to use
I have a B20 block with a GSR head. The Block is built. The head is stock. I have a T3/T4 turbo and it was recently tuned on hondata on 11psi making 301HP and 245 Tq. I am due for an oil change and I would like to know what suggestions should I use. Obviously synthetic. I live in FL so I was thinking 10w40 in the summer and 10w30 in the winter. This will be my first oil change on this set up. thanks
Old 08-09-2014, 03:55 PM
Turbo-LS's Avatar
Default Re: Suggestion for What Oil Weight to use
Who built the motor? They should've provided bearing clearence and recomendations on what weight oil you should be running.
I don't like to run anything less than valvoline VR1 racing oil but that was years ago. I personally run Joe Gibbs XP6 oil in my car. But it's not a street car
Old 08-09-2014, 04:09 PM
marcs23's Avatar
The previous owner had the block built so I am not sure about bearing clearance. The previous owner told me he ran 10w30 or 10w40 but if he ran it hard, he would use 20w50. All of these were synthetic. This is not my daily driver and I need to do an oil change and Not sure what I should use. The motor was built a little over a year ago. thanks
Old 08-09-2014, 05:34 PM
Turbo-LS's Avatar
What kind of oil pressure are you seeing with 10w30?
Old 08-09-2014, 07:12 PM
ls joker's Avatar
my input is vague. but i basis my oil off of oil pressure and bearing clearances
Old 08-09-2014, 08:57 PM
marcs23's Avatar
I do not have an oil pressure gauge. I do plan on getting one.
anyone else?
Old 08-10-2014, 07:59 PM
F22Master's Avatar
Rotella T6 is always a good choice. It only comes in 5w40, but that should be fine for you. It also has plenty of good additives that your turbo and engine will love lol
Until you get an oil pressure gauge you will really never know.
Old 08-11-2014, 01:27 AM
4tika4's Avatar
rotella t6 here too
Old 08-11-2014, 07:02 AM
marcs23's Avatar
thanks everyone
Old 08-11-2014, 08:03 AM
boostjunkie757's Avatar
i run 5w30 synthetic in mine.
Old 08-11-2014, 10:06 AM
Swaggylicious
$amGD3's Avatar
Running Rotella 15-40 here because 1.cheap 2.decent reviews 3. needed a thicker oil due to old motor
Old 08-12-2014, 08:00 AM
speedjunkie_g35's Avatar
Location: Pensacola, FL and every Court House in Louisiana
I use the same.
Old 08-12-2014, 06:53 PM
welfarepc's Avatar
I think VW did a goob job figuring out what oil to run so it lasts.
5w40 synthetic. All day, err day.
With that being said, I run Rotella 15w40 in summer and dont drive it in the winter. But if I did have to drive in winter, 5w40 so it gets up and around the engine quicker when cool VS a 15 weight.
Old 08-13-2014, 12:37 PM
Premium Member
Aradin's Avatar
+1 for the Rotella. Been using the 15w40 conventional since I built my motor a couple thousand miles ago, also previously used it on a stock block setup. Planning on switching to the T6 next oil change. My dad also swears by the stuff and uses the 10w30 Synthetic blend in almost every piece of farm equipment and all the vehicles he has. I noticed this stuff is very resistant to thermal breakdown and excessive high temperatures as compared to some other conventional oils I tried like Pennzoil, Valvoline, etc.
Old 08-15-2014, 06:13 AM
DA 4 Lyfe's Avatar
I use 10w40 Brad Penn
Old 09-16-2021, 01:01 AM
james8's Avatar
rotella t6 prefered here too
Old 09-16-2021, 07:38 PM
Tunerbuilder's Avatar
Rotella T6 seems to be a reliable go-to for what I've run.
90Rexx
04-28-2008 06:42 AM
turbochargeb18c
06-18-2005 04:20 PM
Mr. JDM-GSR
03-29-2004 02:14 PM
ALL MOTA
05-01-2003 09:20 PM
crxhybrid1320
02-07-2003 05:22 PM
Quick Reply: Suggestion for What Oil Weight to use
