Honda CR-V & Element 2WD & 4WD Element & CR-V
Need advice, 98 CRV motor sounds like marbles from 3k-4k rpm
Old Aug 4, 2014 | 12:24 PM
badbuik's Avatar
Default Need advice, 98 CRV motor sounds like marbles from 3k-4k rpm
I need some advice/help. I acquired a 98 CRV,4 cylinder, 166K miles. I had to change timing belt, wp, seals, all that stuff when ya do a timing belt, did a valve adj, only like 2 exhaust valves needed tweaking, replaced cap and rotor, plugs, injectors, car had some issues that I had to address. we've been driving it, and I noticed that under load, 3k-4k it i thought it was "pinging", motor sounds like marbles rattling around, I ran higher octane fuel, still does it, rechecked timing, then advanced it 4 more deg. book says 14-18, so its now at 22. Still rattles, same rpm..Idle ok, but not as smooth as I'd expect, cleaned the throttle body, checked for vacuum leaks, tested the IAVC, or whatever its called, un plugging it idle drops very low, hooking it back it returns to where it was, so I'm assuming its working... I thought I had everything covered but it still "rattles".. Kinda pisses me off, I'd like to sell it, the average "joe" might not even here it, but I want to fix it, any suggestions????
Thanks, Gary G.
Old Aug 4, 2014 | 05:38 PM
tony_2018's Avatar
Fish Twig
Default Re: Need advice, 98 CRV motor sounds like marbles from 3k-4k rpm
Have you checked your exhaust system?
Old Aug 4, 2014 | 07:44 PM
jayjazmin's Avatar
You sure it's not your catalytic? It hear shield rattling?
Old Aug 4, 2014 | 07:56 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Advancing your timing only makes the problem worse. You need to retard it and see if it goes away assuming it is in fact detonation. Pull your plugs and check for detonation before you potentially blow the engine.
Old Aug 4, 2014 | 08:29 PM
badbuik's Avatar
It's defiantly not heat shield rattling. I'll try and retard the timing and check the plugs, to see what happens.
Thanks
Gary G
Old Aug 5, 2014 | 08:55 AM
shermanyang's Avatar
Marbles in a tin can.....and you changed timing belt? That's a recipe to cook up Detonation. Better check your timing marks to make sure they're all aligned properly otherwise your motor is toast.
Henry Tyre
May 19, 2019 01:24 PM
chipper
10
Jul 4, 2013 10:59 AM
jpnolan
Jun 10, 2013 04:29 PM
freseray
Apr 20, 2011 08:50 PM
pliskin679
Apr 3, 2010 04:12 PM
