98 civic ex just changed belts and now idle is crazy
Old 04-20-2011, 06:40 PM
freseray's Avatar
Default 98 civic ex just changed belts and now idle is crazy
I do not know much about cars. I have a 98 civic ex and it was leaking oil so I had to change the camshaft and crankshaft seals. I took all the belts off and timing belt.
Now when I drive the car, sometimes when I clutch or am in neutral, the car still idles high (while moving, and when I am standing still). Then today (about 2 days later) one of the belts started squeaking when I started up the car.
The idle problem did not occur before I changed the belts. I did check the throttle and it does not seem stuck. Any thoughts?
Old 04-20-2011, 08:50 PM
HondaGuy951's Avatar
Default Re: 98 civic ex just changed belts and now idle is crazy
I would say have ur timing done. Anytime you do your timing belt, you need to adjust your timing again.
Meraut
05-08-2013 09:43 AM
StevenGunn
11-21-2010 03:23 PM
violarules
03-18-2008 10:53 AM
llevity
07-12-2005 02:39 PM
curiousgpnoy
01-20-2004 11:16 AM
Quick Reply: 98 civic ex just changed belts and now idle is crazy
