Where to buy head gaskets and screw?
So do you want reliable, or do you want cheap? No such thing as both. If you want good, suck it up and buy an OEM head gasket kit. If you want cheap, go to your local parts store and buy whatever they have on the shelf, but be ready for it to last 3 months, tops, because you won't do all of the other necessary, required work involved in replacing a head gasket. Seriously, it's not as simple as "take the old one off, put the new one on". There are no "screws" in the intake manifold, or anywhere in the exhaust system. You either want bolts, studs, or nuts.
And I've gotta ask... what is the reason for the head gasket replacement? Are there any (known) underlying issues that caused it to fail? You'll need to take the head to a machine shop. Trust me... I did my HG twice. The first time was cheap, and the second time was right.
P0420 has nothing to do with a bolt.
Your coolant leak might be just that - a leak. Do the proper tests before you start throwing parts at your car. Start with a block test.
Did you find the source of the leak? Reading your other posts, it sounds like the coolant was leaking onto the ground... that's not a typical head gasket failure.
EDIT: If you mean the coolant leaked out, causing the HG to fail due to overheating, that makes sense. But you *must* take the head to get checked.
Auto parts store or eBay. Take your pick. Doesn't matter since you're only doing this to make this car last until your next one. But mind the advice you're given. If the head isn't true, or the parts fail prematurely, you'll be doing this again.
Just throwing an OEM head gasket at it after it's overheated and been sucking coolant into the combustion chamber isn't going to give you reliability.
If you don't want to do it twice then you will also have to take the head to a machine shop to test for warped condition, cracks etc.
Why would you go through all the trouble to do it wrong? Buy the OEM or cosmetic gasket. Get either OEM or arp bolts. Send the head to a machine shop to get cleaned and inspected. While you are there, might as well do the timing belt and water pump.
if it isn't warped it doesn't need to be milled, but more than likely its warped. If the valve play is within spec, it doesn't need the guides replaced.
krisfnbs
Dec 17, 2008 09:03 AM
arielb1
11
Nov 5, 2004 02:38 PM
E Swift
Nov 15, 2002 07:31 AM
