Installed new speed sensor, didn't fix!
Old Aug 3, 2014 | 12:02 PM
paintballer1184's Avatar
Default Installed new speed sensor, didn't fix!
I have a 98 ex with a working tach, fuel and oil guage. Speedometer doesn't work, got the code so I replaced the speed sensor. Didn't do anything, what could it be?
Old Aug 3, 2014 | 02:54 PM
Bently_Coop's Avatar
Steve at Heart
Speedometer can be replaced, try a different cluster.
Old Aug 3, 2014 | 03:55 PM
holmesnmanny's Avatar
Obviously the wiring from the sensor to the ecu is bad since the tach works fine
Old Aug 3, 2014 | 05:01 PM
Default Re: Installed new speed sensor, didn't fix!
is this easily replaceable? it does seem the connector has seen better days. A bad cluster would give off a cel?
Old Aug 4, 2014 | 02:45 AM
HondaPartsHero's Avatar
Technical Hero
A lot of times these VSS connectors get corroded due to the location they are in and the connectors either break or the connector itself breaks causing a bad connection.
http://www.clubcivic.com/board/showthread.php?t=180280
vader3234
Mar 1, 2018 05:49 AM
Freckles
Aug 20, 2012 10:30 PM
aziaticvang
Jan 13, 2008 06:35 PM
hip_hop_s0ulchild
Mar 1, 2007 03:41 PM
slow4dr
Dec 27, 2004 07:19 AM
