Fresh D16Z6 install, first start up and purges
Old Jul 26, 2014 | 05:40 PM
civicboy420's Avatar
Default Fresh D16Z6 install, first start up and purges
Success guys, I have done my first complete rebuild of my Z6, started up no problem, so happy. Now the crappy part, It starts purging on me cutting in and out. All the sensors are in there correct locations, and I have a check engine light. Also the radiator hose is really hot, but my temp gauge says normal. Do you think it could be air in my system that is causing the in and out purge? Is there a way to check the codes? I have the Rywire OBD0 to OBD1 jumper harness and there is two wires that connect together to show the CEL, yet no codes show up. Thanks for your help in advance guys
Old Jul 26, 2014 | 05:43 PM
Fliptard's Avatar
Default Re: Fresh D16Z6 install, first start up and purges
Bleed the poop outa the coolant system. Jack the front of the car up. open the rad cap and let it run. Add coolant as necessary, sometimes it takes foreverrr.
Old Jul 26, 2014 | 05:49 PM
Old Jul 26, 2014 | 10:14 PM
I just relized when I first tore down the motor for rebuild, I had to relieve the fuel pressure. I forgot to lock the gas cap back up. Would that cause surging idle or a check engine light?
Old Jul 26, 2014 | 10:23 PM
4drEF's Avatar
Keyboard Humorist
You have a check engine light.
Do NOTHING without first checking for what the trouble code is.
Old Jul 26, 2014 | 10:26 PM
I put the two wires together from my harness that show the codes and shows no codes. just constant cel.
Old Jul 27, 2014 | 09:49 AM
HondaPartsHero's Avatar
Technical Hero
Have you tried it while it was running and the CEL is on?
Old Jul 27, 2014 | 11:17 AM
I don't remember if I did or not. I will try it again tomorrow and let you guys know. I was also thinking about getting it timed correctly and cleaning my IACV.
Old Jul 27, 2014 | 07:25 PM
4drEF's Avatar
Keyboard Humorist
It doesn't make any sense to do any work until you know what the problem is.
There seems to be something wrong with your service connector if the cel isn't blinking when you short the connector.
This is the same connector that needs to be shorted in order to set timing so ...
Try shorting the D4 pin on the ECU to ground. This is what the service connector does so no worries. (Key must be turned to "ON")
Old Jul 28, 2014 | 09:34 AM
I dont know what the problem is, everything is connected right, I bled the cooling system, and there is still a god dam check engine light with no ****** codes this is bullshit! I dont need to short the D4 pin since I have the two wires that specificly say Check CEL. Brand new motor and it runs like garbage. When it's cold, its runs smooth, then the idle bounces between 500 and 1500. I dont know what to do.
Old Jul 28, 2014 | 09:51 AM
4drEF's Avatar
Keyboard Humorist
Apparently your two wires aren't working or you would see the CEL blink.
Short D4,
Old Jul 28, 2014 | 10:02 AM
The two wires and ecu were working before the rebuild. How can I short D4 if I have a jumper harness? Where do I unplug it from?
Old Jul 29, 2014 | 11:32 AM
Jumped D4 and D22, still solid check engine light. I know my harness and ecu are good. I don't what else to do.
metraxik
Mar 22, 2013 01:35 AM
sergeant dukesalot
Apr 2, 2010 07:47 PM
hondamike89
Feb 23, 2009 07:44 PM
EK45VTi
Nov 21, 2006 12:51 PM
project90crx
Nov 15, 2005 01:12 PM
