D16A Built for boost
Old Jul 23, 2014 | 09:02 AM
def90man's Avatar
Default D16A Built for boost
Hi all, quick question
I just recently built my bottom end a d16a for a greddy turbo kit, going to begin at about 7-12 pounds
D16A
Eagle h-beam rods
JE pistons 9.4:1
ARP studs
Stock d16y8 head
I blew my current d15b7 i was wondering if i could swap in the d16 with out the turbo at the moment if i use my p06 and intake manifold / injectors from the d15b7?
Later on change to the p28 and 440 DSM when i install turbo/Tune... this is my daily unfortunately and it blew before i could finish my swap/turbo
Old Jul 23, 2014 | 09:18 AM
Freemananana's Avatar
Default Re: D16A Built for boost
Yes. You can swap the block, keep the same intake/injectors/etc and run on the stock ECU.
Old Jul 23, 2014 | 10:48 AM
def90man's Avatar
Thank you!
I was mainly worried of any changes to air/fuel ratio etc
t12tninja
Jul 7, 2011 08:16 PM
pelacuas
Nov 5, 2010 01:47 PM
bobbycreek
May 13, 2008 07:02 PM
Bc3
Apr 26, 2007 01:59 PM
UnKnOwNsLeEpEr
Apr 26, 2004 03:54 PM
