A/C and Heater vent issue.
Old Jul 22, 2014 | 03:25 AM
dperry's Avatar
Post A/C and Heater vent issue.
Hi, cold air and heat only comes out of the door and floor vents in my 92Si. What do I need to check? The center vent was working but just stoped. Thanks for pointing me in a directon.
Old Jul 22, 2014 | 05:56 AM
yohan's Avatar
Default Re: A/C and Heater vent issue.
Probably your climate control unit, do a search for re-soldering the climate control.
You'll have to take out the piece above your stereo (with all the buttons on it) for directing air to defrost, floor, vents etc. then solder where the wire harness plugs into it. This happens in pretty much all of our cars.
Old Jul 26, 2014 | 04:15 AM
luzer91's Avatar
yohan is right, I did mine '93. all vents work now. clock was blinkin too, resolderd clock plug. fixed it also. Hardest part about getting climate box out is the temp controll cable off/and back on.The hole job is just about an hour anyway.(don't loose no screws)
Old Jul 28, 2014 | 04:47 PM
dperry's Avatar
Ok. Thank you. I was thinking that it was probably one of the levers that move the flaps to the open and close position was sticking. I have read how to's on fixing this issue but they never seemed like the issues described in the threads & post applied to my problem. But ha, Thanks again for pointing me in the right direction.
Old Aug 21, 2014 | 07:31 PM
dperry's Avatar
I performed the re-soldering repair for the AC unit and it worked.
a video link for this repair.
dE.fUsEd
Aug 28, 2013 06:12 AM
circusfreak
Jul 16, 2012 12:36 PM
tearlessj
Dec 1, 2011 05:07 PM
blkegcoupe
Aug 26, 2008 05:01 PM
user 528629372
Oct 18, 2005 08:07 AM
