Climate control settings ineffective?
Old Nov 29, 2011 | 08:44 PM
tearlessj's Avatar
Default Climate control settings ineffective?
Every time I turn on the blower, the air comes out of all the vents. Switching from all the settings does nothing. I can't defrost my windows! Any ideas? Thanks
Old Dec 1, 2011 | 02:45 PM
fadedej1's Avatar
Default Re: Climate control settings ineffective?
is the wire from the climate control connected? the one that runs down underneath your glove box
Old Dec 1, 2011 | 03:19 PM
sebTeggy's Avatar
Depends, that only adjusts temperature.....
I'm assuming your temperature works fine, but your vents function doesn't work? Sounds like the motor or assembly might not be functioning. Is that what you are talking about?
And are you saying the rear defroster doesn't work? Or since you can't adjust the settings, that ur having fog buildup in the front?
Old Dec 1, 2011 | 04:12 PM
racebum's Avatar
if the hot cold works but you don't have forced air it's probably the blower motor. if you have no heat it's either the check valve or a cable came undone. if you have foggy windows and the heater smells like maple syrup you have a leaking heater core
Old Dec 1, 2011 | 05:07 PM
fcm's Avatar
fcm
Old Fart
MM&Y of car would help.
However it is most likely a problem with the mode control motor or mode control linkage, can be seen from under the drivers side of dash on left side of heater box. 94
Clipsed
Oct 19, 2011 04:53 PM
DC206R
May 6, 2009 04:00 PM
Aj_26
Dec 30, 2007 06:21 PM
D16Z6_turbo
Oct 5, 2007 11:05 PM
