99 ek auto 2 man and motor swap help..
Old Jul 14, 2014 | 04:55 PM
92daSleepa's Avatar
Default 99 ek auto 2 man and motor swap help..
There are tons of auto 2 man guides I just am a tad confused and I would just like a quicker easier answer.
So I have a 99 civic ex auto with y8 I bought a b16a jdm motor I am going to be using obd2b 99-00 em1 (p2t) ecu. I have a obd2b dist. So my questions are do I have to repin ecu at all or am I good with set up? And clutch pedal wise there is the starter cut out switch on clutch pedal what do I do with that? Run it to where? IACV do I have to do anything with this? Again I'm using proper ecu and I'm using same IACV from my y8, do I need to change that? Any help is much apprieated . I will have a few more questions but just these for now. Thanks
Old Jul 14, 2014 | 06:37 PM
eghatch9295's Avatar
Stancetard Hate Monger
Default Re: 99 ek auto 2 man and motor swap help..
2 wire iacv conversion. your 99 auto y8 uses a 3 wire throttle body mounted iacv, b16 uses 2 wire. i typed out everything you need but deleted it. there are numerous detailed write ups for auto to manual with pics on here.
Old Jul 14, 2014 | 08:52 PM
crazyhouse2011's Avatar
you need a 2 wire iacv.
you also don't need to install a clutch switch. it can save your life if you ever stall out in an emergency or the car dies in a busy intersection, you can use the starter to pull your car to safety.
Old Jul 15, 2014 | 10:31 AM
tony_2018's Avatar
Fish Twig
Check the FAQ section, there's a how to guide, seriously its all there.
Loyalhondahaver
18
Jul 16, 2024 11:38 PM
ekrgm
10
May 29, 2011 08:05 AM
be18see1
Aug 15, 2008 01:24 PM
BOOSTEDP5
Jul 5, 2006 09:49 PM
BlackCRX
Feb 16, 2004 01:51 PM
