b18b1 swap into del so
Old Jul 2, 2014 | 04:33 PM
cookie541's Avatar
Default b18b1 swap into del so
I'm doing a b18b1 swap into 1993 del sol. I have a p75-a04 ecu I was wondering if that will work are do I need a conversion harness. Second motor mount I know b and d series motor mounts are the same does that mean the brackets are as will. Is this a drop in swap. Third what all is needed to do this swap I got motor tranny ecu axels shift linkage motor mounts? Am I miss anything
Old Jul 2, 2014 | 05:26 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: b18b1 swap into del so
Is the B1 OBD1 or 2? Is the ecu OBD1 or 2?
http://civic-eg.com/viewtopic.php?p=...50592496743c80
Old Jul 2, 2014 | 08:58 PM
cookie541's Avatar
Obd2
Old Jul 3, 2014 | 02:42 AM
Technical Hero
Stay OBD1 on the ECU. As for the engine you can reuse your del sol injectors but you'll need an adapter harness for the alternator and distributor or use the OBD1 B18B counterparts. The rest will plug and play.
Old Jul 3, 2014 | 07:53 PM
cookie541's Avatar
Motor mount and t brackets and stuff are all the same I'm taking it
Max713
Aug 2, 2008 02:54 PM
PinoyDelSol
Nov 4, 2007 06:31 PM
Jose-aka-Pedro
Jun 30, 2007 12:56 AM
vtec25
Dec 6, 2006 04:23 AM
93LSTurboSol
Nov 4, 2004 07:53 AM
