Ek 2000 euro r swap try pull out cel code
Old Jul 1, 2014 | 06:01 PM
banshee500's Avatar
Icon2 Ek 2000 euro r swap try pull out cel code
Hi just finish my swap everything run great...except a little surge at 1500rpm n my cel light is upup...so i short the connector for the cel code with a paperclip..put the key on the cel just seem to flash every 5sec...no quick flash nothing just a steady flash every 5sec
Anyone can help me on this thx
Old Jul 2, 2014 | 04:39 AM
LTCxD2B's Avatar
R u sure it's just not a very fast flash ? That is hard to see and looks solid until the repeat...
Old Jul 2, 2014 | 05:32 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: Ek 2000 euro r swap try pull out cel code
Post a video
Old Jul 2, 2014 | 07:10 PM
banshee500's Avatar
http://s1105.photobucket.com/user/ya...13849.mp4.html here the video
Old Jul 4, 2014 | 03:48 PM
LTCxD2B's Avatar
Looks like one long flash which means 10 which means intake air temp
Old Jul 5, 2014 | 05:58 AM
Technical Hero
I agree
Old Jul 7, 2014 | 12:04 AM
banshee500's Avatar
Thx guy ill take a look tomorow...there any way to test the iat sensor?
Old Jul 7, 2014 | 09:42 AM
LTCxD2B's Avatar
There should be some amount of resistance between the two pins since it's just a coated thermistor or I would just reset the Ecu and find another iat that is known to be be good just to check and if it doesn't go away then your Ecu may have a burned component from plugging in the wrong plug from the harness
Old Jul 7, 2014 | 04:22 PM
banshee500's Avatar
Just test the iat seem to be working fine....Trying to reset ecu cel wont just doesnt want to go off as soon i put the key on pop right away...
FourthGen
17
Jun 16, 2019 01:25 PM
pedroa06
Feb 9, 2010 02:42 PM
nixcite
May 16, 2008 09:06 AM
crvtt96
Jun 6, 2004 04:00 PM
