Please help f20b swap
Old Jun 29, 2014 | 07:50 PM
Yogi30's Avatar
Default Please help f20b swap
Hey guys I have a 97prelude with a f20b swap that I just did an it was my first time so this is what's goin on I have a stock p28 ecu with a base map h22 chip now the car runs but it runs like crap It dumps to much fuel into the car an it gets into the motor oil witch is bad so i changed the oil like 3 times already !!when I give the car throttle it bogs down an wants to stall an it pops threw the intake an skips an wen it gets warmed up it's worse... I changed every sensor on the motor an re did the timimg all over an still nothing but when I had the h22 in there it ran fine I never had any problems with it so idk what to do I'm stumped I don't wanna give up also I changed the whole cabin an motor harness because the car use to be auto so I wanted every thing In it from a 5 speed motor but if any one can help please let me know thanks a lot
Old Jun 30, 2014 | 12:00 AM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: Please help f20b swap
So, you have not tuned the car, and wonder why it runs like crap?
Old Jun 30, 2014 | 01:46 AM
Yogi30's Avatar
No I didn't but I did what they told me to do I hope it's right I changed the oil pump to a h22 an crank gear an I also changed the intake manifold to a h22 with the injectors an stock map sensor an I have a chipped p28 ecu so the car has to be tuned is that what ur saying ?? Also was that right that I changed all them things ??
Old Jun 30, 2014 | 05:11 AM
thomasakehoe's Avatar
I think what he's saying is that the"tune" for an h22 is not going to be right for an f20b even though you swapped over the oil pump sensors and gears it still only displaces under 2.0l not just under 2.2 l
Old Jun 30, 2014 | 05:14 AM
Also what sizer were the stock injectors vs the h22 the h22 tune is going to be set to feed the engine more fuel than it needs to start with and if the injectors have a larger flow rating than the f20b did that's even more fuel
Old Jun 30, 2014 | 06:24 AM
HiProfile's Avatar
The tune will be relatively close. At worst, the 10% less displacement would cause a 1.5 point change in AFR's - 13:1 vs 14.5:1. My guess is you have a faulty injector, that's the only way it could be dumping that much fuel. Even at 50% more fuel it would nearly all go out the exhaust - mostly as black soot. To answer the size question, Pre-97 H22's used low-impedance 330cc injectors and 97+ H22/F20B/H23A used high-impedance 290cc injectors. The latency differences can make big differences at lower duty cycles, such as those used at idle.
Timing is totally different matter. The motor has less bore & less stroke, both usually require less timing. If you fix the fuel issue, you may need to retard the entire map a bit (manually via distributor) until you get it tuned.
Old Jun 30, 2014 | 07:31 AM
Yogi30's Avatar
I have stock 97 type sh injectors I don't know what ones 290-310 I'm not sure to be honest but it runs real rough so like I said idk what to do is the best thing to do is get it tuned ??
Old Jun 30, 2014 | 05:13 PM
HondaPartsHero's Avatar
Technical Hero
Is your check engine light on?
Old Jun 30, 2014 | 06:35 PM
Yogi30's Avatar
Nope no engine lights an I hooked my scanner up an nothing comes up idk what is goin on
Old Jul 9, 2014 | 02:12 PM
Yogi30's Avatar
I got the pcb ecu I hooked it up an it still runs like **** idk what to do from here dose any one have any ideas ??
Old Jul 10, 2014 | 12:37 PM
HiProfile's Avatar
From what I've seen the F20B fuel system is like the H22A4 and H23A, it runs 3.5-4 BAR fuel pressure. Get a LS or D16 regulator & cast-style H22/F22A fuel rail to reduce fuel about 7%, or just get an adjustable reg and reduce it 7-15psi. DO NOT get a crappy china-made regulator, they will cause even more problems.
If that doesn't work then you'll have to see if it's basic maintenance stuff (plugs/wires/etc), a clogged EGR system, or just needing a tune.
Old Jul 14, 2014 | 10:40 AM
Yogi30's Avatar
Ok I have the bottom of the f20b intake manifold with the top the h22 intake manifold an I have the stock h22 fuel rail with the f20b injectors an stock fuel presser reg an it runs fine but a high rpm now wen it hits vtec it pops out the intake I believe not sure tho so should I try the d16 pr ls reg still ?
Old Jul 14, 2014 | 03:27 PM
HiProfile's Avatar
I think you should try getting a wideband and a tuner. Your basemaps sounds like it's pure ****. Either pay someone to do some mild street tuning or pay to re-ring the motor several times over the next few years.
Old Jul 15, 2014 | 02:38 AM
Yogi30's Avatar
It's getting street tuned next week an where can I get a wide band an what is that cause this is my first ever doing a swap an should I get it before the tune ?
Old Jul 15, 2014 | 03:19 AM
Yogi30's Avatar
An I also forgot to tell you right now I'm using a p-13 stock h22 ecu but it will be getting tuned on a p-28 ecu an also it's not dumping fuel no more in to the oil
Yogi30
Jul 13, 2014 10:04 AM
dagle
Mar 16, 2010 05:25 PM
ph0ngtran
Mar 24, 2008 03:54 AM
eeleaj
Oct 9, 2006 03:03 PM
darockstar
Jan 19, 2006 04:42 PM
