Radiator fan not coming on help!
Old Jun 28, 2014 | 04:05 PM
EJ8Squad919's Avatar
Default Radiator fan not coming on help!
Today i was driving and I got a CEL. Im running hondata s300v2 and checked what it was and said Over Heating. THe car was running hot and then noticed the my Spal 13" fan isnt coming on. I Jumped the wire to the switch and turned the ignition on and fan didnt come on. I jumped the relay and fan still didnt come on. What could be the problem ?
Old Jun 28, 2014 | 04:08 PM
95accordCE6's Avatar
Default Re: Radiator fan not coming on help!
Did you try running 12v directly to the fan or testing for power going to the fan?
Old Jun 28, 2014 | 04:47 PM
hardcore97's Avatar
did you check the fuse to see if it was blown?
Old Jun 28, 2014 | 05:41 PM
$MIKE$'s Avatar
hopfully the fan motor burned out.. if not looks like you have some wiring issues..
check the fan and make sure it works
Old Jun 29, 2014 | 04:00 AM
wantboost's Avatar
Who is Mr Robot?
run 12v directly to the fan... if it still doesn't turn on then the motors probably dead... New fan time
Old Jun 30, 2014 | 05:26 AM
I havent had time to check the fan hopefully it is the fan. If the fan does turn on. What fuse is the fan? I am running a 13" spal with no relay maybe i burned some wires... I checked everything and looks fine
Old Jun 30, 2014 | 07:29 AM
Just checked the fan and it works when u plug it up to a 12v. Which fuse so I look at? What else should I look for?
Old Jun 30, 2014 | 10:07 AM
V-SPEC 1's Avatar
Check the thermo switch by the thermostat housing, make sure it's connected well and if it is, check to see if it's still un good condition.
Old Jun 30, 2014 | 11:06 AM
Was a blown fuse. Is it because im not running a relay with my spal fan? I put a new fuse and running fine but dont want to keep on replacing fuses. This is the first time this has happened
Old Jun 30, 2014 | 02:00 PM
wantboost's Avatar
Who is Mr Robot?
You need a relay...
but for the relay to work the fan needs to be hard wired to the battery (the proper way)
if you don't do it you'll end up blowing fuses left and right and potentially melting wires causing a fire hazard.
Old Jun 30, 2014 | 06:46 PM
boostlsveg's Avatar
Yea u need a relay. Look on jegs or summit they have the spal relay kit for ~40 bux. It comes with everything u need.
ayemaverick
Oct 5, 2014 12:46 PM
1989 Honda Accord
Jan 3, 2013 06:48 PM
fatl13ert
Oct 22, 2012 12:41 AM
turbo gsr
Jul 9, 2006 01:14 PM
FONK
Jan 12, 2006 03:03 PM
