I'm searching turbo info
Old Jun 25, 2014 | 03:32 PM
Future turbo's Avatar
Default I'm searching turbo info
I'm thinking about turbo my b16a2. I have read and all say I have to now my cv goal (it is around 250 max 300) and a good setup. I want a daily car with regard's for consuption in low rpm and good power in high rpm. I was thinking a ebay kit with a t3/t4 turbo and changing some things internaly. I want it reliable so I need a good setup. Tell me point by point what is that? And what do you think about all this?
Old Jun 25, 2014 | 03:40 PM
B_Swapped93's Avatar
Default Re: I'm searching turbo info
Ebay turbo kit... lmao yah ok have fun with reliability only after a good deal spent having things modified just to get them to fit.
Old Jun 25, 2014 | 04:21 PM
this one:http://www.santerchips.pt/index.php?...product_id=479
Old Jun 25, 2014 | 04:23 PM
which kit do you recomend?
Old Jun 25, 2014 | 04:24 PM
It's a lit hard here to get things well done because most tunning is made in diesel cars so there is'nt a lot of experience with b16a2
Old Jun 25, 2014 | 04:30 PM
My car as all the exahust in stainless steel and I have some changes in the air intake. For the injetors can I for exemple ones from a mercedes 500cc? And which fuel pump do you recomend for my aplication? And what about the ecu manegment? And what changes internaly should I do to make it reliable?
Old Jun 25, 2014 | 04:32 PM
If you don't understand the link I gave is very similar with ebay kits
Old Jun 25, 2014 | 04:49 PM
NotARaCist's Avatar
I never narc'd on nobody!
Stop spamming the forums. Start reading the FAQ sticky.
Old Jun 26, 2014 | 04:34 AM
Schister66's Avatar
Man U FTW
https://honda-tech.com/forums/forced-induction-16/%2A%2A%2Aforced-induction-forum-faq%2A%2A%2A-1024174/
Start by reading this^^
For the record, Ebay turbo kits =/= reliable. Since reliability was one of your main concerns, you can cross those off the list.
Old Jun 26, 2014 | 11:26 AM
thanks i will read more then
Old Jun 26, 2014 | 11:58 AM
thats exactly what I was after. thanks
Old Jun 27, 2014 | 04:21 AM
Schister66's Avatar
Man U FTW
That thread is a great starting point. The next thing I would recommend is to use the SEARCH feature to find setups that you can use as an analog for your upcoming build. The best advice I, or anyone, can give you is to educate yourself. That way, when you ask for advice/opinions, you can separate the fact from the rampant amounts of misinformation surrounding turbo setups.
Old Jun 28, 2014 | 03:21 PM
thanks again. I have time to prepere my setup. I will have from this summer to the next to do it. I'm gathering info. I'm not sure yet if I stay NA or go turbo
me3333
Jul 17, 2016 08:15 PM
rexload
Jan 4, 2012 03:19 PM
92egkirt
Dec 5, 2011 12:45 PM
redline760
Jul 3, 2009 08:59 AM
aaroboost
Feb 9, 2006 08:43 AM
